Whats your 'diagnostic' People
Postby Zyros » Fri Apr 28, 2006 6:20 pm
Still trying to solve this car problem..
When cold, works fine.. when warm the engine cuts in and out..
Always at certain point when you take your foot of the clutch...
And when your driving along when warm, the engine cuts in and out (feels like misfiring) starting from the high gears down to the low.. and gets worse and worse..
Its a problem which has got worse over time, yet the car drives fine in reverse!
Any idea's what it could be?
Zyros
Postby deaf_rattle » Fri Apr 28, 2006 6:32 pm
clutch maybe?
maybe something about it not engaging properly
Postby dazzag » Fri Apr 28, 2006 7:22 pm
what vechicle is it? i saw a ae101 corolla with that problem ended up being a broken igntion wire deep in the loom. when the cluch was released and the engine engaged with the gearbox the wire wont loose contact and the engine would cut out, didnt happen in reverse too
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby Zyros » Fri Apr 28, 2006 7:45 pm
Hmm, i might check under the dash tommorow around the ignition..
ANy other suggestions?
Zyros
Postby dazzag » Fri Apr 28, 2006 7:47 pm
sorry i meant ignition as in distributor signals. the wire was in the wiring loom under the bonnet
dazzag
Postby RS13 » Fri Apr 28, 2006 8:08 pm
Have you checked the ECU for codes? (if you can on those?)
Failing that, take it to Toyota, I'm sure they'd have a diagnostic machine to plug into it, and see what the issue is.
RS13
Postby bluemaumau » Fri Apr 28, 2006 8:15 pm
RS13 wrote:take it to Toyota
if anyones gonna be able to solve it surely its them!
Postby Zyros » Fri Apr 28, 2006 8:40 pm
There so bloody exspensive tho 8O
Yeah, error 13. RPM signal.
Ive dome everything the code suggests (even loom) so looking at other options.
AE92
Zyros
Postby Zyros » Fri Apr 28, 2006 9:00 pm
Edit: Doesnt only do it when warm now!!! Does it after a few min's warmed up eg - less than 2,
Zyros
Postby Zyros » Tue May 02, 2006 7:25 pm
Bump
Zyros
Postby RedMist » Tue May 02, 2006 7:41 pm
I'd stick with the 12 signal.
If you can replace the dizzy, and temporarily swap out the ECU. There really is only three options, and you have eliminated one with the loom....
Oh, you do know the RPM signal wire is generally shielded.
It must be earthed and if the shielding is slightly damaged it might be picking up a weird signal from another wire.... hence the stumble and the 12 signal error.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
