Speedo isnt working
Speedo isnt working
Postby 4000GT » Mon May 01, 2006 7:18 pm
Pretty sure its not the sending... so the next most common fixes are...???
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby opticalblue » Mon May 01, 2006 8:02 pm
have you check the plugs to see if the wires may have come loose... do the wiggle test...
opticalblue
Postby 4000GT » Mon May 01, 2006 9:38 pm
opticalblue wrote:have you check the plugs to see if the wires may have come loose... do the wiggle test...
Plugs on the cluster?
4000GT
Re: Speedo isnt working
Postby matt dunn » Mon May 01, 2006 11:48 pm
CircuitLevin wrote:Pretty sure its not the sending...
because...........
Postby opticalblue » Tue May 02, 2006 5:44 am
just the plugs on the speedo circurt...
opticalblue
Postby 4000GT » Tue May 02, 2006 8:44 am
because...........
We replaced it with another.
4000GT
Postby matt dunn » Tue May 02, 2006 11:04 pm
CircuitLevin wrote:Pretty sure its not the sending because we replaced it with another.
Usually a good way to tell.
Have you hooked up anything that may be killing the signal such as speed meter, speed cut defender, etc etc?
otherwise you may be looking at a dash problem.
Postby 4000GT » Wed May 03, 2006 8:39 am
Nothing else is hooked up... I guess the cluster needs to come out. I was hoping there was a relay or fuse that may be causing it.
4000GT
