How to shut up exhaust but still have good flow... 4agte
Postby ~SlideWays~ » Wed May 03, 2006 2:36 pm
Hey,
I've got a 4agte with 2.5inch exhaust with a standard looking 'silencer' (this was on the car when I got it), its not a blingy chrome thing, might be off of another car though. But it drones and is annoying.
I want to shut the phukn thing up.
Can anyone suggest a silencer/muffler which will flow well but be quiet? Or even any other options that there might be.
Cheers.
~SlideWays~
Postby Dell'Orto » Wed May 03, 2006 3:14 pm
Any resonators?
Postby ~SlideWays~ » Wed May 03, 2006 4:05 pm
Mmm, Boost wrote:Any resonators?
When I first got the car it had two but had one removed due to repairs needed to whole exhaust. It didn't sound any different afterwards to be honest.
Will they make that much difference?
I only care about flow, if possible I'd have a totally silent exhaust.
~SlideWays~
Postby RickGT » Wed May 03, 2006 5:55 pm
underlay 8)
my 82 is the same, even with the old gay stock muff it was quite dronie
gna put sound dedening shit in when i get round 2 it
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby barryogen » Wed May 03, 2006 6:02 pm
not overly relevant, but removal of the cat in my car(2zzge) made it as loud as a very loud thing, it has a real 20v buzz/whine to it, horrid sound it is.
Anyway, putting in a high flow cat appears to fix it.
rest of the exhaust is resonator and two mufflers, 2.5" front to back
barryogen
2ZZ Guru in training
Postby Jebus » Wed May 03, 2006 11:43 pm
Just put a 2 chamber flowmaster, or similar turbo style muffler somewhere along it, will quieten it down and still flow good.
Jebus
Postby Dell'Orto » Wed May 03, 2006 11:54 pm
Yup, I had a muffler in my MR2 that I got from Southwards, was all of 250mm long, with offset/offset ends and a hollow section in the centre. Was amazingly quiet, considering it was a full 3" system off the turbo, with a big shiny bling cannon at the rear.
Postby Stealer Of Souls » Thu May 04, 2006 11:20 am
Jebus wrote:Just put a 2 chamber flowmaster, or similar turbo style muffler somewhere along it, will quieten it down and still flow good.
Gotta be careful when buying "turbo" mufflers. A lot are a dog leg style which have comparably terrible flow rates... And some aren't even all that quiet...
IMO the only way to silence exhausts are using more silencing devices. Fit a high flow cat and a muffler, and if you can cram one in a resonator. Make sure they're all at least the same internal diameter as the pipework... There are plenty of stories out there where a 2 inch muffler has an ID of a tad under 2 inch. In fact, to be safe perhaps aim for an ID that is a quarter inch larger than the pipework...
Lagging the pipework with heat wrap can help, but isn't cheap... Tends to reduce high frequency ringing sound some exhausts have....
The last possibility (although technically illegal) is some of those butterfly valves that you can stick in the pipework. Apexi do some, as do some aussie people (google oz for Variflow. AES.com.au I think...)
If you've got a friendly WOFer then you might get away with fitting a valve system...
'86 AE85.5 Levin
Stealer Of Souls
Postby barryogen » Thu May 04, 2006 11:44 am
barryogen
