Car jumps while parked
Postby Zyros » Fri May 05, 2006 6:28 pm
Okay, has mentioned in like 9 of my threads tying to fix this..
My car's engine cuts in and out, it progressed from doing it like every 10 seconds (feels like a missfire, engine cuts in and out for like .1 second)
To when only warm, to when i turn it on.. the rev gauage goes crazy and the rev's of the car just go up and down...
What could be causing this..
Ive done the entire distributor, ecu, loom, spark plugs, battery, some of the loom, Leads, Coil, Filters..
Zyros
Postby ee904age » Fri May 05, 2006 9:01 pm
This is a bit of a stab in the dark, but since you're getting desperate for suggestions, have you tried the TPS? Although it shouldn't make the engine cut out completely, it will make the revs fluctuate if faulty/set incorrectly.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby deaf_rattle » Fri May 05, 2006 9:08 pm
i reckon try and rip the alarm out
Postby Zyros » Fri May 05, 2006 9:12 pm
deaf_rattle wrote:i reckon try and rip the alarm out
I tried that, didnt work.
No, i havent tried the TPS, but i didnt think that would give error 13. Might try it, how do i test it.. just unplug it? If so, i think i done that with you mat? (deaf_rattle) it still ran the same.. aka crap.
Zyros
Postby AE91Sprinter » Fri May 05, 2006 9:48 pm
fix the error 13 first, perhaps.
Heres a hint, its an internet forum, its kinda hard to diagnose without seeing the car...
The TPS has nothing to do with the RPM signal.
AE91Sprinter
Postby yobbosayo » Fri May 05, 2006 10:12 pm
Turbo timer?
yobbosayo
Postby Zyros » Fri May 05, 2006 10:28 pm
yobbosayo wrote:Turbo timer?
It aint turbo'd.
I know its an internet forum and hard to diagnose, im just out of idea's.. thats why i post threads to get more idea's to try..
Screw taking it to mechanics / electricians.. $1200 later none of them knew.
Zyros
Postby Alex B » Sat May 06, 2006 2:01 am
Earthing points on the engine been checked? How bout the main battery earth to chassie?
Postby toyrota mota » Sat May 06, 2006 2:03 pm
I dont konw if this applys to you but when my fx was doing a similar thing it was the throttle body all clogged up with rust and shit and some of the coolant input output things on the throttle body had rusted off. so if your getting desperate just take the TB of and check it and give the whole thing a good clean.
toyrota mota
Postby RS13 » Sat May 06, 2006 3:49 pm
Sell it.
RS13
