How to remove OLD gunk from tape on paintwork
Postby snwtoy » Fri May 12, 2006 6:35 pm
I think this has been asked before, and the anwer was elbow grease.. but here goes anyway.
The paintwork on the runabout car I just bought is red, and rather faded/fragile.
At some stage it has had a heavy duty cloth tape holding bits and pieces of trim together, instead of being repaired properly.
This has been removed (a long time ago), leaving unsightly 'gunk' behind. This gunk is about 0.5-1mm thick in places, and seems pretty rock solid.
Has anyone got any tips for removing it, so that I don't damage the paint?
snwtoy
Postby B1NZ » Fri May 12, 2006 6:42 pm
Try some CRC, or go get some prepsol from a panel shop
if that doesnt work, I used some Meths sparingly to remove residue from my old factory toyota stickers
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby trueno_20v » Fri May 12, 2006 6:48 pm
turps?
ADMIN EDIT: signature too large
trueno_20v
Postby Ae92typeX » Fri May 12, 2006 6:56 pm
the aboves + desolvit (sp)another option.
I'd probably carefully pick at it then prepsol then wax.
Ae92typeX
Postby snwtoy » Fri May 12, 2006 9:09 pm
Thanks guys.
Can prepsol be purchased from the likes of repco?
I have turps and meths.. also have some BAM which I might try.
Fingernails are getting a little weary heh..
snwtoy
Postby deaf_rattle » Fri May 12, 2006 9:12 pm
prepsol can be bought from autopaint.
Postby spencer » Fri May 12, 2006 9:36 pm
prepsol, then if all else fails paint thinners get most crap off. just be carefull on your paint
spencer
Postby FXGTV » Fri May 12, 2006 10:32 pm
I used Jiff to get my lame gunk off...
1988 r31 TI Skyline.
FXGTV
Postby spencer » Fri May 12, 2006 10:40 pm
FXGTV wrote:I used Jiff to get my lame gunk off...
works good on your white shoes to :?
spencer
Postby Lloyd » Fri May 12, 2006 11:35 pm
Brake Cleaner
Postby Ae92typeX » Sat May 13, 2006 11:06 am
I would never use Jiff on car paint, its pretty harsh.
lol, once, a now departed aunty used to clean the bird crap off her car with Jiff. It had been freshly painted...the surface got well $&#$% up, and got repainted again. then she got rear ended by some punk lol.
Ae92typeX
Postby Akane » Sat May 13, 2006 1:32 pm
Bug & tar, green can, repco.
Postby RS13 » Sat May 13, 2006 4:19 pm
I just cleaned all the Hello Kitty stickers off my Charade this morning, (yeah yeah, I bought it off an asian..) I tried everything from window cleaner to cut'n polish, nothing worked, kinda just spread it out and made it worse!
I ended up just getting a bit of towelling, and rubbing the crap out of it.. and it worked! With pressure and friction comes heat, and this caused the adhesive to roll up into little clumps, came off mint!
RS13
Postby sam.bzg » Sat May 13, 2006 4:33 pm
I've used meths thousands of times for cleaning up glue from stickers/tape etc. Works a treat 8) .
sam.bzg
Postby AE91Sprinter » Sun May 14, 2006 1:06 pm
citrus based cleaners work very well without compromising the paint.
AE91Sprinter
