Running 7mgte valves in a 4age
Postby no_8wire » Sun May 14, 2006 12:06 am
Has anybody done this? apparently they are 2mm larger... but they're about 2mm shorter than the 4AGE ones, so much thicker shims are needed..anybody know were I can get thicker shims? Or get them made?
no_8wire
Postby Ae92typeX » Sun May 14, 2006 1:08 am
Toyota sell shims, but I dont know if they cover 2mm bigger or not.
Its a bit of head work to put in larger valves, and they dont flow too bad anyway...
Ae92typeX
Postby Mr Revhead » Sun May 14, 2006 1:09 am
No certainly not 2mm bigger 8O
Postby Ae92typeX » Sun May 14, 2006 10:03 am
lol, yeah, didnt think there would be for 4age, -thought there may have been some other model with different sizes. You would be worried about it if you needed a 2mm bigger on on your 4age through wear!
I recall somone a while ago talking about problems with shims staying in. I think it was due to cam. They tacked the shim to the bucket off memory. That may be required here to possibly?
Ae92typeX
heh
Postby ezy10s » Sun May 14, 2006 10:33 am
If youre going to put n bigger valves , why half ass it with shim on top bucket setup- club 4ag has a nice article on a single piece bucket/shim that is a no fuss swap for the 4ag 2 piece buckets.
Why you looking for bigger valves may i ask?
Member #244
ezy10s
Postby Mr Revhead » Sun May 14, 2006 12:37 pm
no_8, talk to the man above..... hes done it before :wink:
Postby no_8wire » Sun May 14, 2006 1:16 pm
Well as I am using the 16v head for my 7agte...I thought I would enlarge the valve size as well, so I can get more fuel in quicker = more power...
Well thats the idea anyway...
:lol:
no_8wire
Postby crnkin » Sun May 14, 2006 3:12 pm
how much more power is the question. the stock size valves have been run up to 400whp
deaf_homo "currrently yes"
crnkin
Postby no_8wire » Sun May 14, 2006 3:35 pm
Yes they prob could...however, just because they have been, doesnt mean that you wouldnt get more power from bigger valves...
no_8wire
Postby deaf_rattle » Sun May 14, 2006 3:51 pm
have you got some 7mgte valves?
Postby jondee86 » Sun May 14, 2006 3:51 pm
Hey ezy10s.... have you done that one-piece bucket conversion ??
Got any idea of the cost of the buckets ?? Are they available here ??
Cheers.... jondee86
Watch this space >>> <<<
jondee86
Postby no_8wire » Sun May 14, 2006 4:08 pm
deaf_rattle wrote:have you got some 7mgte valves?
not yet... just thinking about it at the moment
no_8wire
Postby crnkin » Sun May 14, 2006 4:54 pm
no_8wire wrote:Yes they prob could...however, just because they have been, doesnt mean that you wouldnt get more power from bigger valves...
yes, but i ask again, how much power will you want.
What are you using the car for.
if you run big valves on a formula atlantic ported head on 8.0 compression with 5 pound boost and 304 cams, your really just being silly.
Otherwise its hard to help you, that is why there is knowledgeable people cruising round the forum not answering, as they dont have enough info to give you an answer.
Shimless buckets come in 26 sizes and are around about 270 USD for a set of 17 (one spare)
Toda valve springs are about 120 USD.
Theyd be good for any lift, any power.
http://forums.club4ag.com/topic.asp?TOPIC_ID=138127
If you want to buy them open a pay pal and buy them :)
crnkin
yup
Postby ezy10s » Sun May 14, 2006 5:18 pm
jondee86 wrote:Hey ezy10s.... have you done that one-piece bucket conversion ??
Cheers.... jondee86
Yes have done this conversion- cant quite remember the cost buy if you ask Revhead hell let you know.
Member #244
ezy10s
Postby no_8wire » Sun May 14, 2006 5:36 pm
I want to get 260-300whp...
Though that is only an aim...
no_8wire
hm
Postby ezy10s » Sun May 14, 2006 5:40 pm
dont need 7age for thant dude- just go 4age rebuild and some nice bolt on mods- turbo, link, etc and youll be laughing.
Member #244
ezy10s
Postby no_8wire » Sun May 14, 2006 5:44 pm
I know that...but want something abit different...plus torque is good! :lol:
Plus I want to have a drivable car off boost, as most driving really will be done when full boost isnt on...
But mostly something different.
no_8wire
Postby crnkin » Sun May 14, 2006 5:53 pm
there thats better.
Dont get bigger valves.
It will be chaos in an MR2 (im assuming) and at 260-300 whp, the smaller the ports the better, definitely go for a smallport head with stock valves, on a 7a bottom end, stock rods, bored out to fit 8.9:1 pistons, rebuilt it all nicely, run a link and a t28 or similar, youll be stuggling to get under 300 whp methinks
Big valves will mean really piss poor off boost performance, as will a bigport head.
Grotty's 7agte would be perfect for you....
crnkin
meh
Postby ezy10s » Sun May 14, 2006 5:56 pm
standard ze with decent amount of boost will give you everything you just described except for the different factor, fair enough though somehting different is always fun.
Still- for that sorta ower you wont need much in thw way of head mods, i suggest you ring that guy i mentioned in that pm and he'll see you right
Member #244
ezy10s
Postby CAMB01 » Mon May 15, 2006 8:02 pm
Iv fitted 3SFE valves to my small port head. Valve head is 1.5mm larger in diameter.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Users browsing this forum: Bing [Bot] and 27 guests
