4age blacktop Map/vacuum reading
Postby NA Drifter » Tue May 16, 2006 5:13 pm
Have anyone here got a SAFC or vacuum gauge in their car with blacktop 4age?
I need a vacuum reading at idling.
Keith
NA Drifter
Postby AceSniper » Tue May 16, 2006 5:56 pm
T off the map sensor
AceSniper
Postby 4000GT » Tue May 16, 2006 6:05 pm
AceSniper wrote:T off the map sensor
I think I sit around 18 inches of mercury.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby RedMist » Tue May 16, 2006 6:42 pm
By increasing the volume of pipe wouldnt that delay the map reading and smooth the peaks and troughs that the ECU sees?
I realize effects would be minimal, however its still an adverse effect.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby AceSniper » Tue May 16, 2006 7:04 pm
I dono I dont use map, but its very possable, there is also another vacume feed on the other end of the engine might be a beter choice
AceSniper
Postby suberimakuri » Wed May 17, 2006 5:40 pm
Redmist: that's why factory place the map sensor on a short hose.
In practice, this doesn't seem to matter though. Look at the majority of ecu's out there running onboard map sensor with great results. :)
suberimakuri
Users browsing this forum: Bing [Bot] and 30 guests
