fuel pump mod
fuel pump mod
Postby bluemaumau » Wed May 17, 2006 8:02 pm
ok so this is a 4afe f. pump housing(guess that what you call it :? :lol: )
and a gtz pump
as you can see in the pictures the pump is too big.
Q is which end should i cut a bit off? i would say the pump but it looks like its got something in its outlet.
however if i was to cut the metal lines then it wouldnt have its little lip thingy.
or is there another option.
what do you think
cheers will
note: the pump is not sitting on its little rubber guard which adds another 5 or so mm.
pics:
Postby Lloyd » Wed May 17, 2006 8:24 pm
Cut the bottom off and hoseclamp the pump to the bracket maybe?
Postby no_8wire » Wed May 17, 2006 8:32 pm
buy a gze pump housing? 8)
no_8wire
Postby 20v_rollaboy » Wed May 17, 2006 8:34 pm
Agree with HRT. Cut the bottom off and hoseclamp onto the bracket.
20v_rollaboy
Postby bluemaumau » Wed May 17, 2006 8:54 pm
i dont know of any gtz housings for sale and im not waiting.
when you say cut the bottom off, do you mean the metal pipe from the housing? this will mean ill lose the little lip.
will
Postby 20v_rollaboy » Wed May 17, 2006 9:42 pm
No not the pipe from the pump. The bottom plate or housing where the pump sits on. Once the pipe is on the pump (main feed) and the clamp is holding the outside of it, its not gonna go anywhere.
20v_rollaboy
Postby bluemaumau » Wed May 17, 2006 10:48 pm
yea sweet as, just wanted to make sure.
cheers everyone
ryno, is that your new plate?
which corolla is it going on?
would suit either aye
Postby trueno_20v » Wed May 17, 2006 10:57 pm
well tonight i put a ze fuel pump in my car, had exact same problem as you, so i just cut the top peice about 10mm all going sweet now :oops: :lol:
ADMIN EDIT: signature too large
trueno_20v
Postby sergei » Wed May 17, 2006 11:44 pm
or you could use a longer hose and do a loopy S on the thing... jsut make sure it is fuel hose and rated well above pump pressure...
Postby bluemaumau » Wed May 17, 2006 11:52 pm
ok, well it least if mine dosent work, neither will yours trueno_20v. :lol:
bring on the hack saw :twisted:
Postby loose_unit » Thu May 18, 2006 12:09 am
Did the same thing on the starlet when i put a sw20 pump in, just chopped about 10mm off that pipe. Its been in the car about 50,000k now and never had a problem.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby gepsk8 » Thu May 18, 2006 12:09 am
get a new filter to while its out!
gepsk8
Postby postfach » Thu May 18, 2006 6:43 pm
i had the same problem when putting a bigger pump in my car, ended up cutting some of the metal pipe off and flaring it out with a screwdriver to make a new lip thing, i also used a big hose clamp to hold the pump onto the pickup. not gonna go anywhere without a lot of help.
postfach
Users browsing this forum: Bing [Bot] and 15 guests
