Hi all. I've got an AE92 FXGT. It's got a 16V TVIS 4AGE in it.
The air con pump has $hit itself, so was wondering if I could put an SC12 in it's place.
I'm guessing it'd be running quite low boost maybe 5psi or so.
Can this be run with the standard computer and injectors?
I have a few things that might help. I've got a SAFC II that could be used to adjust fuel to suit. How about a rising rate fuel pressure reg? Would that be needed? Also, would I need to get 4AGZE injectors?
I've heard of people turboing their standard NA 4AGE and getting good gains. I'm only after a lil more power (more down low bang) and would like to give this idea a go.
Any thoughts/comments/ideas would be apreciated.
Cheers.
