SC12 on N/A 4AGE AE92 FXGT???
Postby Crampy » Sun Jun 04, 2006 5:24 pm
Hi all. I've got an AE92 FXGT. It's got a 16V TVIS 4AGE in it.
The air con pump has $hit itself, so was wondering if I could put an SC12 in it's place.
I'm guessing it'd be running quite low boost maybe 5psi or so.
Can this be run with the standard computer and injectors?
I have a few things that might help. I've got a SAFC II that could be used to adjust fuel to suit. How about a rising rate fuel pressure reg? Would that be needed? Also, would I need to get 4AGZE injectors?
I've heard of people turboing their standard NA 4AGE and getting good gains. I'm only after a lil more power (more down low bang) and would like to give this idea a go.
Any thoughts/comments/ideas would be apreciated.
Cheers.
Crampy
Postby bluemaumau » Sun Jun 04, 2006 5:43 pm
were is the a/c on a 4age?
front?
just turbo it man, way less hassle
Postby crnkin » Sun Jun 04, 2006 5:46 pm
I replied to your pm
safc's suck, fpr's suck, unless its a FMU type. I have one.
Basically go turbo, then realise you want more power, and spend 970 on a link.
deaf_homo "currrently yes"
crnkin
Postby Mr Revhead » Sun Jun 04, 2006 5:54 pm
as far as can u run an sc12 on that engine ok then yes u can, i am.
as far as can u put it where your talking.... no u cant
Postby Crampy » Sun Jun 04, 2006 9:01 pm
Cheers.
By the look of things, going turbo is the easiest. I still find it hard to believe I can turbo and not need to change anything like injectors and computer etc (well as long as i keep boost low)
Now all I need is well everyhting to get it done. How hard is it modify the sump for an oil return and get an oil feed for the turbo? What else do I need? Hmmm, turbo, intercooler. Yep, sounds good, I'll be getting onto it soon as.
Crampy
