'help' 3sgte problems
Postby 1loose_mr2 » Fri Jun 16, 2006 4:19 pm
hi
i own a celica gt4(st185), and im having problems with the engine.
it all started when i installed a pod filter.
the first thing i did was remove the stock filter and i remove the air flow metre aswell,so that i could bolt on a adapter ,then when i reinstalled it,i forgot to plug the AFM in lol, and then i cranked it over,it started,reved to about 2000 and then the revs droped to about 500rpm and then it stalled.
so i remembered that i forgot to plug the AFM in.so i plugged it in,cranked it over,it was running fine for about 5 seconds and then again the revs droped to 500rpm and stalled.
so what have i done to the engine? ecu problems? AFM problems?
help me please ,i just want it on the road again
thanks
1loose_mr2
Postby RS13 » Fri Jun 16, 2006 4:21 pm
Tried resetting the ECU? Disconnect the battery for 10mins?
RS13
Postby 1loose_mr2 » Fri Jun 16, 2006 4:33 pm
just disconnect the battary,hope it works
1loose_mr2
Postby 1loose_mr2 » Fri Jun 16, 2006 5:06 pm
just started it again.now it cranks over and just stalls staight away.
so what now?
1loose_mr2
Postby solitaire » Fri Jun 16, 2006 5:20 pm
1loose_mr2 wrote:just started it again.now it cranks over and just stalls staight away.
so what now?
Check the engine diagnostics... it should be in the bgb...
search for mr2 bgb in google and check it out mate...
AE92, KZJ120, KDJ120
solitaire
Postby blackmk3 » Fri Jun 16, 2006 5:25 pm
check for anything loose you didnt plug back in...also check the connections on the AFM plug to the AFM might be dirty give em a clean with some electical cleaner, also check the wiring for that plug when you took it off you may have broken a wire....
if all else fails put the standard filter back in and try that might be worth a shot
Mk3 MA70 Supra
blackmk3
Postby Lanius » Fri Jun 16, 2006 5:26 pm
so what now?
The only things you've removed are the airbox and standard filter? At a guess, I would say there is still a problem with the AFM connection, or there is a leak between the AFM and throttlebody, so theres more air than the AFM is reporting to the ECU, hence the stalling. Double check all the connections for the AFM, and check your piping for any holes or splits.
Lanius
Postby 1loose_mr2 » Fri Jun 16, 2006 6:51 pm
i did remove the intercooler so i can mock up a front mount but i put it all back together,and went for a drive,it was all sweet.
i remove all the pipes from the turbo to the filter but put it all back together
properly, it shat it self when i started it with out the airflow metre connected.i was drivering my car with out a air filter for a night and had no problems so i think its got nothing to do with the filter
1loose_mr2
Postby Norty » Sat Jun 17, 2006 8:05 am
Had the same problem when i did some changes to the AFM piping to Turbo inlet, I would start the car and it would stall, the problem was there was leaks between the AFM to turbo on the piping, i found my piping from the turbo had a massive crack underneth it and that was what was causing the issue, i tighten it up as tight as i could to get it all working again but replaced the pipe and the car runs 1000% better, i suggest you check all your connections are tight, once i had fixed mine the car does not suck the gas and it runs so much better power wise
Norty
Postby 1loose_mr2 » Sat Jun 17, 2006 7:33 pm
i check all the connection,i tighten all the bolt as tight as i could,checked for cracks and there was none.it still doesnt go.
i dont know what to do now? the car looks like its on its way to death valley
1loose_mr2
Postby slighty_sykotic » Sat Jun 17, 2006 8:17 pm
Maybe silly... But is the afm the right way around?
I had mine backwards once.... :oops: lol.
Did the same thing as yours.
If not, my money is on a major vaccum leak.
--Sykotic
slighty_sykotic
Postby YeMs » Sat Jun 17, 2006 8:48 pm
sounds like an afm problem. u didnt drop it or anything wen u pulled it off? u havnt forgoten to put any of the breather lines back on by chance?
pull the plug off the afm and check u havnt pushed any of the connectors out...
Your local Hybrid Elite tech
YeMs
Postby Lloyd » Sat Jun 17, 2006 8:58 pm
If you use the throttle, can you hold the revs up and prevent it from stalling?
Postby 1loose_mr2 » Sat Jun 17, 2006 9:08 pm
yip,i have to keep on tapping over 2000revs to make it not to stall
1loose_mr2
Postby slighty_sykotic » Sat Jun 17, 2006 10:21 pm
That sounds like a massive vaccum leak if it will run with throttle.
slighty_sykotic
Postby Lloyd » Sat Jun 17, 2006 10:26 pm
Yeah, my thoughts too. If you can keep it going then its likely to be vacuum issues. Have a good hunt around
Postby crnkin » Sat Jun 17, 2006 11:55 pm
when you drive it what happens
deaf_homo "currrently yes"
crnkin
Postby mr_monkey » Sun Jun 18, 2006 11:39 am
how did you disconnect the AFM. you didnt undo those little screws in an attempt to remove the plug?
-Nathan
mr_monkey
Postby Rob » Thu Jun 22, 2006 8:11 pm
On mine I ended up getting the fuel pump re wired straight to yhr airflow meter and that fixed the problem
Good luck :wink:
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby 1loose_mr2 » Fri Jun 23, 2006 12:20 pm
ive fixed it. :P turns out it needed some gas 8O the tank was on empty but not on petrol light so thought it had gas in it,so i put 5 litres of 98 in the tank and it fired right up and ran mint lol thanks for all your help guys
1loose_mr2
