I want to use 8.5 c/r turbo pistons for the 20 valve, and i want to use aftermarket cams n cam gears etc in it
Whats gasket should i use for this? And also is it true that "cams match the turbo not the engine"? If so can someone please shed a little bit iof light on this matter for me?
Thanx Jason
