4AGE turbo querries.
Postby FYADUP » Wed Jun 21, 2006 11:10 pm
I want to use 8.5 c/r turbo pistons for the 20 valve, and i want to use aftermarket cams n cam gears etc in it
Whats gasket should i use for this? And also is it true that "cams match the turbo not the engine"? If so can someone please shed a little bit iof light on this matter for me?
Thanx Jason
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby Bazda » Thu Jun 22, 2006 2:15 pm
told u to use trd metal headgasket and email kelford about cams, prob wana get 272s
Postby RedMist » Thu Jun 22, 2006 2:21 pm
If you are talking about huge boost you may want to look at O-ringing the block.
Cams and cam timing will be determined on a host of criteria. Head flow, boost, application. As stated you are best talking to a cam grinder about this.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby 4000GT » Fri Jun 23, 2006 8:03 pm
RedMist wrote:If you are talking about huge boost you may want to look at O-ringing the block.
I know $&#$% all, but I do know in some circles an o-ringed block and wide metal ring gaskets dont work well together...
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby RedMist » Sat Jun 24, 2006 8:30 am
Wasnt suggesting he use a wide metal ring gasket. I think O Ringed blocks are generally mated to a copper gasket. However I'm not certain, as such I didnt mention it.
RedMist
