Radiator leaking - GT-T
Postby snwtoy » Sun Jun 25, 2006 1:15 pm
I've just had the radiator out of my car (had to get part of broken radiator cap out), and I've reinstalled and refilled with coolant.
It has sprung a very slow leak :? This is a pic of the underside of the front of the car, looking up from the ground (cover removed).
It will create a puddle of coolant about 10-15cm across on the ground in 24 hours.
Its definitely not leaking from higher up, as the area around the prong bit is completely dry. Interestingly, if I slightly loosen the bung, it starts dripping more, so I wonder if the bung is supposed to seal the hole for this as well?
If it comes to it I will just have to drain it again, and have a proper look at the bung - it's possible I may have dislodged an o-ring or something as I was in a hurry.
snwtoy
Postby Chickenman » Sun Jun 25, 2006 1:35 pm
you could put a bit of sealed hose over the drain pipe if there's no apparent reason for it (after disassembly)
Baby Jesus
Chickenman
I Am The Walrus!
Postby snwtoy » Sun Jun 25, 2006 1:37 pm
Chickenman wrote:you could put a bit of sealed hose over the drain pipe if there's no apparent reason for it (after disassembly)
Ahh, but on a toyota, there's a reason for EVERYTHING.
snwtoy
Postby Mr Revhead » Sun Jun 25, 2006 1:38 pm
yep thats the outlet for the drain......
id say u dislodged the oring or it got some crap stuck in it
Postby Chickenman » Sun Jun 25, 2006 1:44 pm
no disassemble? :lol:
I hope you used dot 4 antifreeze!!!! :wink:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Crimson Tears » Sun Jun 25, 2006 3:35 pm
Indeed it is the radiator drain bung. If you pull that drain bung right out you will notice a little rubber o-ring on the end, try replacing that. Whenever you replace the coolant on a car that hasn't had a coolant change for a while there's a good chance you'll spring a leak somewhere.
Crimson Tears
Postby snwtoy » Sun Jun 25, 2006 4:45 pm
Chickenman wrote:no disassemble? :lol:
Bastard. You made me go and look at the bottle. And I know full well that dot ratings don't even apply to antifreeze. :oops:
snwtoy
Postby Chickenman » Sun Jun 25, 2006 7:14 pm
Lol.
Made my night :lol:
Baby Jesus
Chickenman
I Am The Walrus!
Postby Bling » Sun Jun 25, 2006 7:22 pm
sorry, but that made mine too :lol: :lol:
Postby TWSTD » Tue Jun 27, 2006 5:55 pm
Mine leaked from there also bud - just block it with a bung :-)
Click here!
TWSTD
Postby blitza » Tue Jun 27, 2006 9:34 pm
fyi, I had to replace the top tank, got it done locally, cost $150
MAD Industries Limited
blitza
