upgrade ae92 to superstrut calipers>? worth it
Postby escortman » Thu Jun 29, 2006 11:00 pm
i looked into up gradeing the brakes on the fx and found that the twin pot calipers off the superstrut cars are a easy fit, a few minor changes needed. or just get some better pads?
4x4 toyota blizzard offroader
escortman
Postby Dragger_Dan » Fri Jun 30, 2006 12:04 am
If it's the same FX you are going to turbo, the yes, you will need them.
Dragger_Dan
Postby escortman » Fri Jun 30, 2006 10:34 am
o ok
escortman
Postby Distrb » Fri Jun 30, 2006 1:45 pm
They're an easy fit if you can do the machining yourself. And if you have the oppertunity to get the parts for a decent price, then why not? It'll only work in your favour.
You dont necessarily need to change all the brakes when you turbo it. Many applications only require a better set of pads, and maybe a caliper refresh to be able to stop the vehicle adequately.
Distrb
Regular Poster
