pyro_sniper2002 wrote:Since when has trust been a toyota genuine part![]()
No, no it isnt factory...
avinesh wrote:does the trust exhust come standard on mr2 turbos.....
Al wrote:Yeah I'd say the exhaust is the reason it creeps up. If your car was 100% stock with the t/vsv connected and the car is up to temp, outside air isn't freezing and the ecu detects no knock it should boost up to 11.8psi. When the t/vsv isn't operating or disconnected it should provide actuator controlled boost of ~7psi.
