How to tell difference between 4k and 4k-u
Postby ollieboy » Sun Jul 16, 2006 6:29 pm
I have two 4k's. One is in my car and the other one makes a nice door stop. They are both running. The one in my car is a 4k but I'm trying to figure out whether or not the other one is a 4k-u which is the japanese model I believe? and I think it has higher compression head? Correct me if I'm wrong.
How can I tell if it is definately a 4k-u or not? It has japanese stickers on which leads me to believe it is a 4k-u.
ollieboy
Postby Dell'Orto » Sun Jul 16, 2006 6:51 pm
Take the head off and look at the pistons. 4K-U's are dished with a flat head. Its only 8 bolts ;)
Postby ollieboy » Sun Jul 16, 2006 6:54 pm
ok cool, I'll go have a look then.
Is it better to have a 4k-u in a race car?
Ive heard it is but is it true?
ollieboy
Postby Dell'Orto » Sun Jul 16, 2006 6:56 pm
They have a little bit more torque than a standard 4K, but not so much more that its worth the half hour to swap engines :lol:
Swap the heads, then you'll have some fun ;)
dont actually do this, unless you want 15:1 compression or 7:1
Postby RS13 » Sun Jul 16, 2006 7:27 pm
I had a 4K-J out of a KP61, those things are nuts! Totally standard, was much faster than any other 4K I've ever driven, although the only thing I could see different was the emissions gear?
RS13
Postby scott900 » Fri Jul 21, 2006 1:35 pm
thats all the "-u" stands for - emissions spec.
scott900
Postby Snoozin » Fri Jul 21, 2006 2:25 pm
4K-U also came in 2 versions as I understand, the "twin squish" heron head type combustion chamber, and a regular type.
The twin squish I believe is the later type, reputedly the gruntiest 4K with a whopping 74 Toyota-hp.
Snoozin
Postby Mr Revhead » Fri Jul 21, 2006 5:18 pm
thats about 62 real world hp for you n00bs :P
Postby TrouserFxGt » Fri Jul 21, 2006 9:45 pm
nice
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
