Lanius wrote:Sooo ... you've removed all your boost cuts and safety features, been boosting it, and you're wondering why your engine check light is coming on?![]()
avinesh wrote:did a diagnostic an came up with code 22 which means water temp sensor..... called beyond motorworks an they told me i will have to replace the sensor..... i called toyota genuine parts an their asking 120 buks..... is there any other place i can get this at a cheaper price also tried toyota manurewa they didnt have it in stock.....
solitaire wrote:avinesh wrote:did a diagnostic an came up with code 22 which means water temp sensor..... called beyond motorworks an they told me i will have to replace the sensor..... i called toyota genuine parts an their asking 120 buks..... is there any other place i can get this at a cheaper price also tried toyota manurewa they didnt have it in stock.....
Email mr revhead... look on the car parts section, there is a sticky from mr revhed and it has an email address to contact him on...
Toyota Manukau will be able to get it in... you may be able to get it cheaper but do you really want to go cheap on a part that measures when your engine is cooking? its only $120 and it will last years...
The car is 16 years old, your look at at least $300 to get it up to scratch if it hasnt been serviced properly... and it WILL die soon at that boost if it hasnt been looked after
