unstable rev when head lights are on after new ECU HELP!!
Postby dougsop » Wed Jul 19, 2006 8:49 pm
anyone knwo why is my rev unstable??
i toke my GT4 st205 to TP to tune my power FC, after the tune i realise when ever the car come to rest the rev is unstable, it will drop below 500 and rev back up to 1100, or some times it just die. The unstable rev last for around 15-30 sec and it will go back to normal afterward.
taking the car back to TP on friday but does anyone knwo why is like that ?
dougsop
Re: unstable rev after tuning
Postby Crucible » Thu Jul 20, 2006 6:38 pm
dougsop wrote:anyone knwo why is my rev unstable??
An engine will only fluctuate in revs like that if air is bypassing the throttle plate. Either being a vacuum leak, faulty stepper motor, or Aux air valve etc. Some cars are fitted with cold start idle up valves and will give these symtoms if the coolant level is low.
Check the above.
Crucible
Real Life Mechanic
Postby dougsop » Fri Jul 21, 2006 12:24 am
thx for that.
but i realise the real problem was that TP drain my battery while they where doing dyno :P
they car battery was running very low, so it was unstable, specially when i have those 8000K lights on at night :P.
is getting better now after a day of driving around :D
but thx for the info :D
97 Toyota GT4 ST205 1st run 16.2psi 181.2KW
more to come...
dougsop
Postby dougsop » Mon Jul 24, 2006 8:06 pm
ok. it is not the problem with the battery.
the unstable rev continue.
unstable rev occur when the head lights are switched on. (tested for both factory and aftermarket headlight).
car run fine during the day when the lights are not on, but once lights are switch on rev drop below 500.
the funny thing is that it will only happen when the light switch is turn on and not when i keep the flashing high beam on.
so does that mean something to do with the switch and ecu ?
help plz ?
anyone know why ?
more to come...
dougsop
hmm
Postby ezy10s » Mon Jul 24, 2006 9:57 pm
i dunno if the power fc has this function but i know a couple aftermarket ecus have a voltage clamp function, which will stop the power being sapped too much when electrical loads are turned up aka lights on , stereo on, etc. if your ecu does have this it may not have being set correctly(if at all) or your ecu may not have provision for this tyrpe of adjustment.
Member #244
ezy10s
Postby ROBODISCO_20v » Tue Jul 25, 2006 5:59 pm
Install an earthing kit & voltage stabiliser, it will help.
http://www.trademe.co.nz/Trade-Me-Motor ... 371034.htm
ROBODISCO_20v
Postby Alex B » Tue Jul 25, 2006 7:34 pm
Do you have any proof of that or are you talking out your ass? If you have suffecent earthing that will do sweet $&#$% all.
Postby RedMist » Tue Jul 25, 2006 7:40 pm
Check the above.
I ditto, CHECK THE ABOVE.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby fivebob » Tue Jul 25, 2006 8:17 pm
Also check the ignition map in the idle zones. It should be constant over the entire idle range. If it varies it can affect the idle stability.
Postby ROBODISCO_20v » Wed Jul 26, 2006 6:03 pm
pyro_sniper2002 wrote:Do you have any proof of that or are you talking out your ass? If you have suffecent earthing that will do sweet $&#$% all.
http://nzhondas.com/phpBB2/grounding-wi ... highlight=
ROBODISCO_20v
Postby fangsport » Wed Jul 26, 2006 6:46 pm
Check the above.
or connections to them.
Robodisco, quoting that link, has merely exposed a weakness of yours.
an earthing kit will be an improvement if your existing earth points are shite.....................or you are after some bling.
fangsport
Postby Alex B » Wed Jul 26, 2006 7:40 pm
Thanks for proving my point by posting that thred :lol: :lol: :lol:
Postby fangsport » Thu Jul 27, 2006 3:43 am
pyro_sniper2002 wrote:Thanks for proving my point by posting that thred :lol: :lol: :lol:
don't get me wrong. earth is vital.........but blinging your engine bay with fancy neon looking wire will only be of use if the factory earth points arn't doing their job.
it is far cheaper(albiet, less bling), to cure the initial problem, than to spend drug money on crap that may work, but dosn't fix the initial prpoblem.
fangsport
Postby dougsop » Thu Jul 27, 2006 1:49 pm
already have bling bling earthing kit.
i guess is the idle on the power FC that is not set probably, and it should be tweakable. taking it back to TP tomorrow and see how it goes.
more to come...
dougsop
Postby ROBODISCO_20v » Sat Jul 29, 2006 11:11 am
My comment about the earthing kit was in reguards to this:
dougsop wrote:ok. it is not the problem with the battery.
the funny thing is that it wll only happen when the light switch is turn on and not when i keep the flashing high beam on.
so does that mean something to do with the switch and ecu ? anyone know why ?
No factory earths are adequate when you start modifying.
My levin had two crapy thin wires for the earth from factory. After I install an earthing kit my digital volt meter in my SAFCII never drops below 14.2v, with the factory earth it would drop right down into the 13s. I think I even saw it drop into the 12s once. I know its not a huge difference but at least I know my stero, head lights, ignition etc are getting the max voltage available to them
ROBODISCO_20v
Postby dougsop » Mon Jul 31, 2006 10:31 pm
problem now solved by TP
it was the problem with the idel setting in the engine bay, they need to adjust that to match the PFC
more to come...
dougsop
