An engine will only fluctuate in revs like that if air is bypassing the throttle plate. Either being a vacuum leak, faulty stepper motor, or Aux air valve etc. Some cars are fitted with cold start idle up valves and will give these symtoms if the coolant level is low.dougsop wrote:anyone knwo why is my rev unstable??
i toke my GT4 st205 to TP to tune my power FC, after the tune i realise when ever the car come to rest the rev is unstable, it will drop below 500 and rev back up to 1100, or some times it just die. The unstable rev last for around 15-30 sec and it will go back to normal afterward.
taking the car back to TP on friday but does anyone knwo why is like that ?
True-No-Turbo wrote:An engine will only fluctuate in revs like that if air is bypassing the throttle plate. Either being a vacuum leak, faulty stepper motor, or Aux air valve etc. Some cars are fitted with cold start idle up valves and will give these symtoms if the coolant level is low.dougsop wrote:anyone knwo why is my rev unstable??
Check the above.
pyro_sniper2002 wrote:Do you have any proof of that or are you talking out your ass? If you have suffecent earthing that will do sweet $&#$% all.
or connections to them.RedMist wrote:True-No-Turbo wrote:An engine will only fluctuate in revs like that if air is bypassing the throttle plate. Either being a vacuum leak, faulty stepper motor, or Aux air valve etc. Some cars are fitted with cold start idle up valves and will give these symtoms if the coolant level is low.dougsop wrote:anyone knwo why is my rev unstable??
Check the above.
I ditto, CHECK THE ABOVE.
ROBODISCO_20v wrote:pyro_sniper2002 wrote:Do you have any proof of that or are you talking out your ass? If you have suffecent earthing that will do sweet $&#$% all.
http://nzhondas.com/phpBB2/grounding-wi ... highlight=
pyro_sniper2002 wrote:Thanks for proving my point by posting that thred![]()
dougsop wrote:ok. it is not the problem with the battery.
the unstable rev continue.
unstable rev occur when the head lights are switched on. (tested for both factory and aftermarket headlight).
car run fine during the day when the lights are not on, but once lights are switch on rev drop below 500.
the funny thing is that it wll only happen when the light switch is turn on and not when i keep the flashing high beam on.
so does that mean something to do with the switch and ecu ? anyone know why ?
