ke70 wagon
ke70 wagon
Postby DOHMAN » Fri Jul 21, 2006 8:56 pm
im looking at buying a ke70 rolla wagon with a 3t motor in does it need to have a cert for the different motor in it or is it sweet without it
DOHMAN
Postby TE71_gurl » Fri Jul 21, 2006 10:11 pm
If it's not the original motor then yes, it needs cert.
TE71_gurl
Postby Dell'Orto » Fri Jul 21, 2006 11:25 pm
Yes it will need to be certed. You might get away with it wof-wise, but if you have a prang...no insurance for you
Postby DOHMAN » Sat Jul 22, 2006 9:42 am
how much does it cost for a cert, coz the guy said that it doesnt need a cert coz that same shape and year wagon came out with that motor
DOHMAN
Postby wde_bdy » Sat Jul 22, 2006 11:07 am
Biggest load of rubbish ever, he's just tying to sell you a car. When the factory puts a bigger motor in they also generally put in bigger brakes, stiffer springs, stronger diff, different proportioning valve etc etc. Its not a matter of just dropping the motor in. Did they swap the front crossmember or just make new mounts? What about steering, as wagons were available both rack and pinion or with a steering box but the T series Corollas all have a steering box setup.
The reason for certing is to ensure that either the whole lot has been swapped or that any mixed and matched parts work together safely. General cost starts at $350ish.
Callum
wde_bdy
Postby DOHMAN » Sat Jul 22, 2006 9:09 pm
all good i decided not to buy i bought a 1980 morris panel van instead :lol: :lol: thanks for the help guys, dont worrie my realtoy is still a toyota the morris is a advertising vehicle for my business
DOHMAN
Postby Bling » Sun Jul 23, 2006 12:22 am
pics of the morry! :D
Postby DOHMAN » Sun Jul 23, 2006 2:25 pm
heres a pic of my morris panel van not that flash but its goin to be resprayed dont no wat color tho.
this is my 2003 caldina shes standard at the moment except a pod filter
DOHMAN
