Radiator upgrade for 4agte..
Postby lorolla24 » Tue Jul 25, 2006 9:45 pm
Hey,
Woundering if there are any easy upgrades for a ae101 20v radiator. just gone turbo and want to beef it up as it has already got a crack in it and have to get it fixed.
Cheers boyz
lorolla24
Postby Lloyd » Tue Jul 25, 2006 9:52 pm
Just go standard. Had a standard 20V radiator in my AE92 with turbo Silvertop and no fans and it never got past halfway
Postby crnkin » Tue Jul 25, 2006 11:05 pm
alloy honda picka part!
deaf_homo "currrently yes"
crnkin
Postby THA SHZ » Tue Jul 25, 2006 11:45 pm
toyota corona diesel twin core , your bottom tank will fit on but a custom top will have to be done but will beabsolutely perfect for wot u want , i am using this in my 4agte . 8)
THA SHZ
Postby evil_si » Wed Jul 26, 2006 1:28 pm
standard is fine.
evil_si
Postby IH8TEC » Wed Jul 26, 2006 2:20 pm
std ha been fine for me too
Postby gmacrae » Wed Jul 26, 2006 11:46 pm
the standard 4age radiator is a pretty capable unit, just find a mint late model one to replace yours
gmacrae
Postby slighty_sykotic » Thu Jul 27, 2006 11:19 am
Another to confirm the std unit is capable.
Runs fine in my 4agte, and its hard a fair bit of thrashing.
--Sykotic
slighty_sykotic
Postby flygt4 » Thu Jul 27, 2006 8:06 pm
just to disagree , im on my 4th standard one :oops:
things to make sure of tho....
dont use too a cap that is rated too high , i had issues with a trd radiator cap , and once i changed it i never had that problem again. :? the old plastic top tanks get really brittle over time when exposed to heat (ie right by ur turbo) and spring leaks.
do secure the radiator properly.. i used cableties and everything i could find in addition to the 2 top mounting brackets. i damaged a core from it flexing backwards under hard or sudden accelleration into a hoseclip on the intake behind it , problem hasnt reoccured since i fixed it properly.
other than that , yeh make sure you have a decent latemodel one with good top tanks and she'll be right mate :D
flygt4
