big port 4age: high pitched squeel from air intake
Postby Pies » Wed Jul 26, 2006 6:54 pm
what is the high pitched squeel from my air intake (or that area) when my foot is lightely on the gas. im only gettin it when the car is under load, not in nuetral, and its farkin irritating!
its a hell of alot more noticable when im running the car with a pod filter (or no filter at all).
can anyone shed some light on this?
Current Rides:
Pies
Postby deaf_rattle » Wed Jul 26, 2006 7:02 pm
is it a whistling sound at all?
i noticed with my 5mge that when i was running a pod filter instead of the factory air box i would get a whistle sound coming through the intake.
might be something as simple as that, nothing can be done about that i dont think, unless i re did my intake pipe or something.
Postby Pies » Wed Jul 26, 2006 7:04 pm
90% sure its a whistling sound. could hear it through the standard intake with a k&n panel filter but no where near as loud. thought it might be a vacum leak but then i remembered id heard it on my old FXGT, and a couple of others i'd been for a ride in that were using pods.
so im guessing it is just normal. but damn its irritating!
Current Rides:
Pies
Postby deaf_rattle » Wed Jul 26, 2006 7:17 pm
just turn the stereo up another notch or 5 :wink:
Postby CozmoNz » Wed Jul 26, 2006 7:18 pm
Try a 20v with individal throttles on low throttle...
ug..
id say its just airflow through a small gap (same way you wistle through your lips).
Rayne For President!
CozmoNz
Postby Pies » Wed Jul 26, 2006 8:18 pm
deaf_rattle wrote:just turn the stereo up another notch or 5 :wink:
i would... if some prick hadnt stolen it :P
coz, RDHTKKHGKJHGSKJHBJKHBWJKHDBJKS!!!!!!!!!!!!!
ps... thanks for pointing out the obvious
Current Rides:
Pies
Postby Caveman » Wed Jul 26, 2006 8:25 pm
Its the idle screw adjuster. Screw it all the way in and the noise goes away, along with the ability to idle.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Adamal » Wed Jul 26, 2006 9:29 pm
I've got that whistle goin on too. Only happens at certain throttle positions. If you open it up more and more throughout the rev range, you can keep it whistling a while :D
Postby Pies » Wed Jul 26, 2006 9:33 pm
Adamal wrote:I've got that whistle goin on too. Only happens at certain throttle positions. If you open it up more and more throughout the rev range, you can keep it whistling a while :D
i made it wolf whistle hehehe
come to think of it, my SW20 did it too. meh. i can live with no idle, this sound however, is just fuken irritating. wonder if i put a bit of thread tape on it
Current Rides:
Pies
Postby Adamal » Wed Jul 26, 2006 11:05 pm
My SW doesn't, you sure that wasn't turbo spool you were hearing?
From memory, didn't the Gen 2 3SGTE have TVIS??
EDIT: After delving into the FUQ section, and reading a post by Malcolm (As well as seeing photographic evidence supplied by him), I see that yes, they did have TVIS.
I'm wondering if its to do with the TVIS plates causing a resonation of air through the small gaps between them and their housing at different air velocity?
Postby Jebus » Wed Jul 26, 2006 11:26 pm
Smallports do it too quite loudly with a pod filter.
Jebus
Postby gmacrae » Wed Jul 26, 2006 11:33 pm
my bigport does it too, at a certain amount of light throttle, nothing to worry about
gmacrae
Postby Ako » Thu Jul 27, 2006 10:18 am
Half the FXGT's I've ever seen all made a hell of a whistley noise when they boot it (relative term :lol: ),
Always wondered what it was, its only those I seem to notice doing it.
Ako
Postby Pies » Thu Jul 27, 2006 12:33 pm
well after a 2 hour drive last night i am absolutely sick to death of it. im going down the road to buy sum sellys no more gaps and im gonna fill the $&#$% out of it.
will post results...
Current Rides:
Pies
Postby Caveman » Thu Jul 27, 2006 10:01 pm
Does get pretty annoying but pies... lol
Maybe fill it with something you can remove first haha but do post results
AW11 Track Toy
Caveman
Postby Adamal » Thu Jul 27, 2006 10:07 pm
It doesn't bother me at all. I surprised how you can get so worked up about it! :D
Postby Pies » Thu Jul 27, 2006 11:12 pm
Adamal wrote:It doesn't bother me at all. I surprised how you can get so worked up about it! :D
i stress out easily :P
well i tried it. filled the manifold with expanding foam and quickly stuck the pod on the end and started it before it set so that air would still be able to get through and make its own little path. works fuken mint now. im guessing that some of the no more gaps set on the pistons, raising the compression to unbeleivably high levels. now im blitzing 20v's!
seriously...
looks like im just gonna put up with it for now. hopefully will have stereo in again soon as insurance pays out :)
Current Rides:
Pies
Postby Trls250s » Fri Jul 28, 2006 7:57 am
Gotta hate it when pricks steal your stereo. I got the same problem but a hole in my muffler... its all i can hear when i cheese it.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby B1NZ » Fri Jul 28, 2006 6:12 pm
sounds like you've dropped an oiled up pig down there pies, try coaxing it out with an apple :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby fuel » Fri Jul 28, 2006 8:24 pm
I think its the noise of the air going passed the throttle plate when its partially closed. Mine did it once I removed the stock airbox and filter. Put the standard airbox and perhaps a K&N panel filter in it with stock resonance chamber to get rid of the noise.
LOUD NOISES!!!
fuel
