Converting from Power Steering in AE92
Postby ~SlideWays~ » Wed Jul 26, 2006 9:50 pm
I'm thinking of removing the power steering from my ae92.
Is there a common toyota with a manual rack which will bolt in? ee90 maybe?
Has anyone done this and what is needed?
I've recently replaced the steering arms so hopefully these aren't different...
~SlideWays~
Postby Pies » Wed Jul 26, 2006 10:08 pm
can i ask why? ive heard rumours of the AE/EE non power steering having a shorter lock to lock but i cant remember exactly
Current Rides:
Pies
Postby Mr Revhead » Wed Jul 26, 2006 10:14 pm
yeah why?
power steering lets u run more caster.... caster is good
Postby Ae92typeX » Wed Jul 26, 2006 10:29 pm
Ive sold a few ee90 ones in the past and to my knowledge they fitted.
By steering arms, do you mean the outer tie-rods?
as above really, why.
none of my cars have p/s...:( wish at least one did lol.
Ae92typeX
Postby Caveman » Thu Jul 27, 2006 12:35 am
Im after the same thing.
If you need reasoning
- weight
- driving style
- access
- reliability
- power
im going to try an ee90. will post up results
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Mr Revhead » Thu Jul 27, 2006 10:06 am
- weight feck all extra
- driving style improved caster = better
- access harden up :P
- reliability its a toyota.........
- power you wont notice the difference
the only reason i can think of is your only interested in drag racing
lets consider this.....
world touring cars
V8 super cars
wrc
fia gt
they all use power steering
Postby ~SlideWays~ » Thu Jul 27, 2006 11:24 am
Why because the ps sucks balls. It fails at motorkhana's and keeps throwing belts off, which gets expensive.
I've got a spare gtz ps pump but the pulley doesn't line up.
Both Leon and PC have had the same problem with the ps failing with quick lock to lock turns.
Plus its too fricken light, I don't like it.
~SlideWays~
Postby Mr Revhead » Thu Jul 27, 2006 11:26 am
then there must be something wrong with it, fix it
adjust the caster, will make it heavier and handles better
a manual rack on those is very very wrong for motorkhana. they are horrible :?
Postby Leon » Thu Jul 27, 2006 12:14 pm
[quote="~SlideWays]
[/quote]
This is true ... however, before you ditch the power steer, I think you probably might want to talk to PC again, now that he has removed the power steer in his car. I believe many of the words he may use in that conversation may be swear words, and describe the difficulty in driving his car now.
Postby ~SlideWays~ » Thu Jul 27, 2006 1:02 pm
Hmmm interesting...
Revhead: main problem I have is that I will need a custom pulley due to having to have the belt on the outer pulley of the crank. This is due to have the alternator being on the other side of the engine and can only have this belt line up with the inner part of the crank pulley.
I have a ps pump from a gtz which I stripped which didn't seem to have the full lock problems. But the pulley just doesn't line up :?
Old man just bought a lathe...maybe can do something about this pulley problem.
You guys are all pussy's! Stupid p/s. :lol:
~SlideWays~
Postby Mr Revhead » Thu Jul 27, 2006 1:06 pm
whats the engine?
fill us in on the details and mods. coz surely u can use the stock set up, weather it be ee100 or 4agze
my aw11 doesnt have power steering.... and with 6-8 deg castor its a bit hard on the steering, but i can handle it.
so harden up yaself :P
Postby ~SlideWays~ » Thu Jul 27, 2006 1:28 pm
Mr Revhead wrote:whats the engine?
Nah its a ae92 gtz with turbo. Can't have the alternator and that HUGE bracket in the stock position because its in the way on turbo setup. Thats why the alternator is now on the side where the sc used to be.
Might see what I can do about modifying the pulley on the spare p/s pump. Just need to be lengthened an inch or two to line up with the outer crank pulley. The current one is a bit bung and the pulley modification isn't too good.
~SlideWays~
Postby Jebus » Thu Jul 27, 2006 1:31 pm
Does a 4AGE PS Pump line up better than a GZE one?
Jebus
Postby Mr Revhead » Thu Jul 27, 2006 1:32 pm
oh yep i got ya
maybe a trip to pickapart to look at various models brackets etc?
Postby ~SlideWays~ » Thu Jul 27, 2006 1:59 pm
Jebus wrote:Does a 4AGE PS Pump line up better than a GZE one?
Not sure, could be worth a look.
~SlideWays~
Postby ~SlideWays~ » Thu Jul 27, 2006 2:01 pm
Mr Revhead wrote:oh yep i got ya
Hmmm, could actually be an option to make a spacer to move the whole pump to the left. Don't remember if anything is in the way... will look tonight.
~SlideWays~
Postby Jebus » Thu Jul 27, 2006 2:03 pm
Cos on 4AGE the alt is on the inlet side, and PS is on exhaust, ive still got the pump + pulley from my motor. Ill take a pic of it for you if it would help??
Jebus
Postby ~SlideWays~ » Thu Jul 27, 2006 2:06 pm
Sweet that'd be good. Cheers
~SlideWays~
Postby ATAl » Thu Jul 27, 2006 6:27 pm
Not having power steering isn't an issue, I've done this and have increased the caster at the same time and the only difference is I can't parallel park one handed anymore.
However, the steering is a little slower ratio now, maybe half a turn more lock to lock.
I used an EE90 or non ps AE92 rack (they seem to be the same), you do need to change the steering wheel to rack universal joint and the firewall side cover, everything else bolts up.
ATAl
Postby IH8TEC » Thu Jul 27, 2006 6:31 pm
use the 4age powersteering pump and bracket, thats what i had to do, and barry made a little adjuster for it.
