Hi all.
I've got got some new suspension bits for my AE92 FXGT. Got Jamex springs and KYB shocks, a one piece front strut brace and an adjustable Whiteline rear swaybar.
How do I adjust the camber up the front? It doesn't have an adjustment on the top bolt like my AE82 FXGT had.
Any suggestions on wheel alignment settings too?
I've seen in an old Hot Fours of mine, an AE82 Corolla got aetup as follows:
Rear camber: -1 degrees
Rear toe: 1mm toe out both sides
Front camber: -1.25 degrees
Front toe: 1.5mm toe out both sides
Caster: 4 degrees postive
Apparently the toe out helps with turn in.
What setting are others using? I'm looking to go for somethine tried and true.
