AE82 FXGT wrote:and when I spin the wheel when its on the car, it makes a metalic type scrapping sound, it does this when straight or turned, this is the wheel bearings right? It happens on both front wheels.
trueno_20v wrote:AE82 FXGT wrote:and when I spin the wheel when its on the car, it makes a metalic type scrapping sound, it does this when straight or turned, this is the wheel bearings right? It happens on both front wheels.
when its jacked up and you spin the wheel? sure its not just the brakes making that noise?
True-No-Turbo wrote:68068g in the link seems to be the common joint for going as ive done on my old and new gtzs, also the front arm joint that its linked gives problems too. The scraping noise will most probly be pads on warning tabs like suggested and wouldnt be related to the worn joints, even though its intermittent.
