painting with lacquer
Postby JamesM » Thu Aug 03, 2006 12:18 pm
i am painting my car. last time i painted it with 2pack enamel. this time i am using a lacquer as its much cheaper for me.
will i need to sand the car back completely (take all the enamel off) before i can prime the car? or is it ok to leave spots of the enamel from before and prime over that? is the primer goign to adhere to the enamel? (its just a surface primer)
thanks
James
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby 2LTR Rona » Thu Aug 03, 2006 12:32 pm
have a read of my reply in this thread
viewtopic.php?t=46145&highlight=car+automobile+paint
Should answer a few of your questions
2002 Altezza, 1974 KE25
2LTR Rona
Postby Ae92typeX » Thu Aug 03, 2006 5:05 pm
with a good sealer primer you can get away with it...can. but ideally, as in the above ref'd link, best to get rid of it.
Ive done both ways and had both fine success, and reaction problems.
If you are planning on keeping the car for some time, and have the better finish without risk of reactions, Id remove.
Ae92typeX
Postby JamesM » Thu Aug 03, 2006 5:35 pm
thanks for the advice. i will remove it all back to the original primer. and then reprimer from there.
Team Megasquirt
1984 AE86
JamesM
