im having a bit of trouble getting a ke70 to turn over from the key; if I short the starter motor wire out it'll crank over fine but theres no power at the key.
is the starter likely to run through a relay which could be stuffed? i've checked all the fuses over the whole car and they are all OK. if it runs through a relay where would this be located? there is a "MAIN" relay in the fuse box in the engine bay; what does this control?
also, on the inside of the fuse box lid there are a couple of diagrams with a heap of numbers on them. they're basically squares which corespond with the wires coming into and out of the fuse box; and the squares have numbers inside them. i cannot work out what these numbers relate to...
anyone provide any information for this?????
cheers.
