Piston interchangability JZ/SGE
Postby strx7 » Mon Aug 07, 2006 9:04 pm
I recall reading somewhere that 3SGE/3SGTE pistons could be used in a 2JZ or 1JZ, cant for the life of me find it again (isn't that always the case when you want info?)
Can anyone tell me if 3SGTE pistons can be used in a 2JZGE (I want to get 8.5:1 compression or thereabouts.
My JZN130, would be alot more fun with 10psi, not that it needs it, but it'd be more fun none the less :)
Any help greatly appreciated.
Thanks
Shane
huh?
Postby ezy10s » Mon Aug 07, 2006 11:07 pm
cant you put the turbo jz in the non turbo engine to achieve the same result? or is there something i am missing here? :?
Member #244
ezy10s
Postby strx7 » Mon Aug 07, 2006 11:11 pm
yeah, what your missing is called the non availibility of 2nd hand 2JZGTE pistons.
Does anyone know if 1JZGTE pistons can be used?
Postby wde_bdy » Mon Aug 07, 2006 11:19 pm
Check some of the US piston catalogues for spec comparisons, there are a feww that list bore, pin height, rod end size etc floating around.
Callum
wde_bdy
Postby Silent Knight » Mon Aug 07, 2006 11:26 pm
3S pistons can be used. They are same bore.
I'll have a set of 2J pistons up for grabs soon.
1 of them might be shot but the other five are fine. Only bout 130$ or so for new 2J piston anyhowz...
Silent Knight
heh
Postby ezy10s » Tue Aug 08, 2006 8:30 am
just boost the std engine- i did it to my 1jzge last year- went blody well, right up until the guy i sold the car to wrote it off
Member #244
ezy10s
