blacktop wont fire -ASAP HELP please!
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 12:45 pm
ok well i turned the key in my blacktop conversion last night and no luck
the starter cranks, but the car wont start
coil has power,
ecu has power
ignitor has power on 2 of the wires
injectors have power
fuel pump is making noises
pulled out a sparkplug, attached a lead and earthed - no spark
(all of the leads are brand new)
any ideas?
this damn car needs to go asap or i wont be making it to trackday!!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby sergei » Tue Aug 08, 2006 12:54 pm
attach test light to injector plug and see if it is flashing while cranking.
If it is not it means that ECU is not getting crank/cam shaft position sensor signal, or there is no sensor/ECU ground attached to the engine.
If it is flashing, that means ignitor is not grounded, or faulty, or coil is faulty.
Check for codes aswell.
Postby AceSniper » Tue Aug 08, 2006 1:40 pm
is this using stock ecu?
as others have said check your grounds
AceSniper
Postby KinLoud » Tue Aug 08, 2006 2:24 pm
A classic is that the ignitor isn't earthed.
Also check all the plugs are plugged in. Tricked myself about 2 weeks ago - could start motor, no spark, found one of the 2 ignitor plugs wasn't plugged in!
Any codes from the computer?
Ken
Ham
021 408 863
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 4:00 pm
havent checked codes (to be honest i dont know how (n00b) - nick didnt wirealot of stuff up, or said it can be worried about later)
standard computer
tried another coil with no luck.
body of the ignitor is earthed (checked with test light/multimeter)
Santa's Mega Sale
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 7:29 pm
and my ignitor only has one plug?
Santa's Mega Sale
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 7:55 pm
pics of my setup here:
http://s22.photobucket.com/albums/b346/ ... h/Racecar/
also, as a double check, should i earth E01, E02, E1, and E2??
W is not connected and i have temp. hard wired the fuel pump (so FC is not connected either)
BATT and B+ definitely have power
and for some odd reason the engine fan always goes when the key is on :S
Santa's Mega Sale
Postby sergei » Tue Aug 08, 2006 8:35 pm
all the E, E0 should be earthed, the fan is running because you have to short an A/C pressure switch plug on the loom.
There is second part to earth which should bolt on to the head.
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 8:38 pm
cool thanks, will try after tea!
the head earth is the brown wires right? (thats connected)
Santa's Mega Sale
Postby Rick » Tue Aug 08, 2006 8:43 pm
Santa'sBoostinSleigh wrote:and for some odd reason the engine fan always goes when the key is on :S
That would be because you have removed air conditioning, there is a pressure switch on one of the ac lines, with it not plugged in makes the fan/s go. either plug the switch back in, or bridge the plug.
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 9:06 pm
any idea which plug?
im guessing its bridging the two prong plug?
Santa's Mega Sale
Postby Rick » Tue Aug 08, 2006 10:04 pm
Iam 98% sure its the one marked in the photo below (which is pluged into the ac lines), I will have to have another look in the day light to confirm. Do you still have the a/c sensors, switches etc.. if so you could try and plug them back into the empty sockets
Postby Santa'sBoostinSleigh » Tue Aug 08, 2006 11:57 pm
its alive!!!!
....kinda
still needs work but she runs
ecu wasnt powered up correctly, its hotwired now
got the fuel working ok
no rev counter
no idiot light
this is the damn rangiest car ive ever owned....
i plugged a socket thingee into the 2prong plug, now the fan doesnt go all the time :) (havent checked to see if it goes when hot yet)
Santa's Mega Sale
Users browsing this forum: Bing [Bot] and 14 guests
