Internal vs external wastegate garret gt3071 performance
Postby Mr_procrastination » Mon Aug 14, 2006 2:53 pm
Hey people. Anyone had any expairence with the Internal and external garret gt3071. Im looking to put one on a resonable modded 3sgte. Can olny seem to find internal wastegated ones in the shops. Thinking i might sell off the tial external wastegate to help finanse the internal wastegated version. Or will i find im cutting myself short on the performance side of thing.
Cheers any expearianced or factual advise would be great.
Mr_procrastination
Postby Mr_procrastination » Mon Aug 14, 2006 6:03 pm
And has anyone had problams with boost creap on the internal version.
Mr_procrastination
Postby Dell'Orto » Mon Aug 14, 2006 6:07 pm
PM Lith, he has been doing alot of research on the GT3071R, I believe he was looking at the internal gated one.
Postby crnkin » Mon Aug 14, 2006 6:18 pm
i think, last time i was turbo shoping, it has a 38mm internal wastegate port.
Either way, id say its past sufficient for the reccomended application. (engine capacity)
deaf_homo "currrently yes"
crnkin
Postby Mr_procrastination » Mon Aug 14, 2006 6:38 pm
Cheers for that the engine has had a rebuild, forges, head work done and a set of bigger cams, BIG throttle body... sort of mods.
Crnkin do you think the gt3071wg is a little on the big side??
Mr_procrastination
Postby cr1mnl » Mon Aug 14, 2006 6:59 pm
could you not just get the internally gated one and weld the wastegate closed and run external or is there something i'm missing? or else surely someone can order the turbo with no wastegate
www.ology.co.nz
cr1mnl
Postby Mr_procrastination » Mon Aug 14, 2006 7:42 pm
well if there is no real differance in the turbos then id happyly go internal.
But there is no way id spend 2+ grand on some thing that wasnt quite right and get happy with the welder!!! If you know what i mean.
Mr_procrastination
Postby crnkin » Tue Aug 15, 2006 7:02 pm
the gt3071 is a frickon bangin turbo, and probably going to make some huge numbers on a 3sgte. Very good turbo choice i'd say. The gt2571 makes 350whp on a 4age, so the gt3071 on a 3sgte will be very close to 500 whp id assume
crnkin
Postby Dell'Orto » Tue Aug 15, 2006 7:11 pm
From what Lith said, avoid the internal gated version, the housing is too small. Among other reasons which escape me right now.
Postby Mr_procrastination » Tue Aug 15, 2006 8:00 pm
Yea ive pm Lith but have had no replie. Id certonaly prefer the external one thats for sure, but of course there is more coin involved. And wonderd why the external version seems to be so much harder to find. Is the internal just more popular? if so why???
Is anyone running one of these? what sort of numbers are being made with supporting mods? Is one likely to find boost creap a problam with a modifyed engine?
The garrett cataloge states the turbo is suited to a 1.8 to 3L engine with a max out up of 480hp. So id asume that it could handle a modified 2L easly. But have seen a couple of not so flash reports on the internal version including report of boost creap. So would be good to get some first hand knowlage.
Timon
Mr_procrastination
Postby Mr_procrastination » Tue Aug 15, 2006 8:05 pm
I was planning on going for .64 ar exhuast housing.
MMM Boost do you know Lith's resoning behind saying the the housing is too small? Surly both the compresser and exhorst housings can just be swapped for higher AR ones.
Mr_procrastination
Postby Dell'Orto » Tue Aug 15, 2006 8:41 pm
He did say, but buggered if I can remember what it was :lol: He doesnt come on here that often, so you might be waiting a while.
Postby flygt4 » Tue Aug 15, 2006 9:07 pm
haha he''l find this thread , but hes just a slack bastard :lol: id say hed have a decent reason as he seems to research thoroughly anything he considers.
flygt4
Postby Akane » Tue Aug 15, 2006 11:23 pm
GT3071R?
you're better off going full GT3040R
The T28 housing is "enlarged" IIRC. But it just won't do it. Totally mismatched wheels.
Postby Mr_procrastination » Tue Aug 15, 2006 11:51 pm
What do you mean by enlarged IIRC???. Id read that the unit has very good spool up, and had seen a couple of dyno sheats on ATP's web sight that tended to show good spread of power from the turbo with the .64 AR exhaust housing.
And it is my understanding that the internaly gated version uses the T25 housing.
Any ideas about the external gated version with the T3 housing?
Mr_procrastination
Postby Akane » Wed Aug 16, 2006 12:00 pm
Well, buy it, try it, and let us know.
Postby Mr_procrastination » Wed Aug 16, 2006 12:29 pm
Lol yea thats one sure fire way to get the answers a :D
Maybe if its no good ill start a raving good thread about it in the Silvia forums then sell it off. :wink:
Then start saving up again :cry:
Mr_procrastination
Postby Akane » Wed Aug 16, 2006 1:04 pm
Well that's how some people find things out, including myself, nobody told me what the GT28RS mated to 3S-GTE would be like, I promptly found out myself.
Yeah sell it off, I recently sold a GT2871R for $1500, and maybe you could go something a bit softer, like a CT20b or something?
Postby Mr_procrastination » Wed Aug 16, 2006 1:10 pm
How did u find the GT28RS mated to 3S-GTE was?
Mr_procrastination
Postby Akane » Wed Aug 16, 2006 1:36 pm
more torque than jesus.
16psi + dodgey 7psi wastegate spring and bleed valve fully opened:
http://lol.co.nz/temp/NOGRIP_Dyno.jpg
