spark plug seals on 4age bigport
Postby Pies » Wed Aug 16, 2006 5:58 pm
how do i get to the spark plug seals on a big port blue top 4age? i have some new ones i want to put in but i really cant be arsed diving into it without knowing where im going
Current Rides:
Pies
Postby Jason T » Wed Aug 16, 2006 7:43 pm
You mean spark plug well seals
Spark Plug Wells Filled With Oil
Q. Hi Vincent, Thanks for the putting all the information in about.com, it is really a great site! I got lot of useful info from there. Recently, I pull out the spark plug wire and found there is engine oil in the plug hold. I really worry about the problem and would like you advise. Is it a big problem I should go fix right away?
Thanks again!
Sawloo
A. There is an O-ring that seals the spark plug well and keeps oil from leaking into it. As with any valve cover gasket, it will start to leak over time. Sometimes tightening the valve cover bolts will stop the leakage, but more often than not the valve cover gasket, and well seals, will need to be replaced.
The seals will come with the valve cover gasket set. I would get it fixed as soon as possible. The oil will cause the spark plug boot to swell and lead to a misfire. This will certainly hurt engine performance as well as a possible engine fire.
Blatant copy and paste from a site my spy ware protection dont like try the link if you dare http://autorepair.about.com/library/faqs/bl023i.htm lots of good info in plan language.
Fixing Toyota's since '87
Jason T
Seals ?
Postby jondee86 » Thu Aug 17, 2006 8:39 pm
Never seen any seals down the plug hole on a 4AGE. The plug connector
is a pretty snug fit, so maybe that seals the gap between the plug and the
head to stop crap, oil etc., getting down the hole ?
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby RS13 » Fri Aug 18, 2006 2:12 pm
Yeah, the 4AGE seems to have 2 cam covers as well. Taking mine off the other day, I had to;
Unbolt the black plastic plug lead cover on top of the motor;
Unbolt the second cover (the bit the plug boot sits in);
And that gets you to the plugs. If they're filled with oil, I would say that your cam covers need tightening, as mine did. I found that out the hard way when I took it for its' first fang, with too much oil, and a blocked breather hose.. my car still smells like burnt oil, lol!
RS13
Postby Pies » Sun Aug 20, 2006 9:02 pm
shot lol
yea im gettin oil on 2 of my plugs (1&2... or is it 3&4... i cant remember)
saw a listing on the computers at work for spark plug seals... but knowing the computer system at work my mates rx3 has piston rings :?
so wasnt too sure if it did have seals or not
Current Rides:
Pies
Oil around plugs....
Postby jondee86 » Sun Aug 20, 2006 11:05 pm
If it is the plugs closest to the oil filler cap, you will often find it is
just the dribbles of oil that get spilled when topping up the oil :oops:
Otherwise, as already suggested, just make sure the cam cover nuts
haven't loosened off.
Cheers... jondee86
jondee86
