Winterizing engines
Winterizing engines
Postby RedMist » Mon Aug 28, 2006 12:51 am
With the Rose transaxle in billions of bits and a new Rally car toy in the garage, the 4age will see little use in the next 9 or so months (until I save the money to put it together again or the 14k for an Ablins) and want to winterize the engine.
I've already drained the fuel and ran the engine dry. I've left the coolant lines attached (Its got a good deal of a corrosion inhibitor antifreeze in it).
Just wondered what everyone else does to winterize, if anything? Fill her to the brim with oil?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby sergei » Mon Aug 28, 2006 1:03 am
in russia we fill the cylinders with heavy oil to stop bores from rusting....
Postby Mr Revhead » Mon Aug 28, 2006 10:44 am
send it to me so it gets used!!
Postby Bling » Mon Aug 28, 2006 1:59 pm
failing that.... due to postage costs, I can just pop around and pick it up for my kp :wink: :lol: got loose? :twisted:
Postby RS13 » Mon Aug 28, 2006 7:32 pm
I'd occasionally run oil down the bores, turn it over by hand a few times maybe.
RS13
Postby NZ_AE86 » Tue Aug 29, 2006 5:48 pm
Fill it with motorup, I saw it on TV - must be true. :D
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Snoozin » Tue Aug 29, 2006 5:57 pm
How long would you an engine be stored before you should need to do this?
I'm asking because I have a 5K which I'm not going to be starting on for some time yet, how long is it safe to leave it until I want to use it?
The old man suggested filling it up to the brim with diesel.
Snoozin
Postby Ae92typeX » Tue Aug 29, 2006 5:58 pm
RS13 wrote:I'd occasionally run oil down the bores, turn it over by hand a few times maybe.
I use this technique occasionally with long standing project engines.just enough oil to cover the bores when cranked by hand afew times.
+ afew drops here and there on other areas.
Ae92typeX
