how the F*ck - superstrut arms
Postby Santa'sBoostinSleigh » Mon Aug 28, 2006 11:02 pm
having a wee bit of trouble getting the damn superstrut arms off
any help?
(see pic below)
(and yes i have undone the nuts!)
its the ba$tard under the CV that is the problem!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby TRDPWR » Mon Aug 28, 2006 11:38 pm
got a really big hammer?
1994 Toyota Celica GT-Four WRC
TRDPWR
Postby strx7 » Tue Aug 29, 2006 12:09 am
TRDPWR wrote:got a really big hammer?
and if that dont work, you need to find an even bigger one!
Postby Santa'sBoostinSleigh » Tue Aug 29, 2006 12:25 am
been there done that
Santa's Mega Sale
Postby blitza » Tue Aug 29, 2006 1:58 am
got heat?
MAD Industries Limited
blitza
Postby msv madness » Tue Aug 29, 2006 8:38 am
you need a bigger hammer and hit it in that perfect spot they are so much fun arent they :lol: :lol: :lol:
www.msv-racing.com, for any fabrication and general mechanical work, aeroquip hose fittings power steer hoses, oil / water turbo hoses, samco hosing, roll cages, custom suspension, engine transplants, driveline transplants, stainless manifolds, alloy, cro moly, stainless fabrication.
msv madness
Postby TRDPWR » Tue Aug 29, 2006 8:51 am
try smacking the @#%^ out of it using a rubber mallet you can use alot of force with those without causing much damage if any
TRDPWR
Postby Santa'sBoostinSleigh » Tue Aug 29, 2006 8:58 am
tried rubber mallet, tried hammer, tried crowbar
dont want tp try heat (rubber bushes etc behind)
might have to get a dumpy mallet and try that
Santa's Mega Sale
Postby Mr Revhead » Tue Aug 29, 2006 10:29 am
get the right tool you muppet :P
Postby Silent Knight » Tue Aug 29, 2006 10:31 am
What you want to do is get a 303 or a 12 guage on the end of that and fire the fcuker loose. :P
Silent Knight
Postby KinLoud » Tue Aug 29, 2006 10:33 am
I think that where the long arm bolts to the hub there is small cotter pin (no pun intended) that holds it in place? Long time since I did this on my old ae101 gtz though. You will have to remove this pin to remove the arm.
The other joint where the short arm bolts to the strut... see if you can't fit it into a press and apply force that way.
One I did was a real pain in the ass the other almost fell apart - a couple of toyota mechanics I know said that when they were bad they were really hard to seperate!
Sadly I have to tell you that it's easier when it is still in the car as not so many parts wan't to move at the same time...
Good luck.
Ken
Ham
021 408 863
Postby Dirtbag » Tue Aug 29, 2006 2:06 pm
When i did it I just got a crowbar, hammer, big piece of wood, its a complete and utter bitch. crowbar down between the 2 arms to pull them apart, i think thats how i got them done in the end.
One of the many joys of S/S :roll:
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby RunningRich » Tue Aug 29, 2006 4:03 pm
Shouldn't have removed them from the car.
First use a hammer either side of the upper balljoint to pop that off (bang bang bang in unison).
Use a tapered prybar between the short knuckle and the lower arm. A short sharp tap on the end of the taper usually pops that off.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Crampy » Tue Aug 29, 2006 4:54 pm
Hey man, sorry to be a hassle with those arms :oops:
No hurry now though, I'm heading over to Malaysia with work for three weeks.
So, hopefully you'll have them free by the 23rd of September :D
I'm not looking forward to getting my ones off and putting those ones in now :cry:
Crampy
Postby Lloyd » Tue Aug 29, 2006 7:45 pm
KinLoud wrote:I think that where the long arm bolts to the hub there is small cotter pin (no pun intended) that holds it in place? Long time since I did this on my old ae101 gtz though. You will have to remove this pin to remove the arm.
A couple of sorts, one with the bolt that goes through and one with a nut on top. Looks to have a nut on top of that one. Only real way to get it off is to bash the hub around the ball joint but with a solid hammer (no point with a rubber/soft one) or using a ball joint separater. The horrible one to get out is between the long arm and the short one.
Postby Santa'sBoostinSleigh » Wed Aug 30, 2006 9:28 am
sorry for the holdup Crampy, i dont want to damage them, hence why im asking for advice!
whats a balljoint seperator worth?
Santa's Mega Sale
Postby Mr Revhead » Wed Aug 30, 2006 9:32 am
DONT use a generic fork type splitter as it WILL root the joint.
got pxt? ill send you a pic
Postby Santa'sBoostinSleigh » Wed Aug 30, 2006 9:40 am
Mr Revhead wrote:DONT use a generic fork type splitter as it WILL root the joint.
yup, you got my number eh? 027 499 6263
Santa's Mega Sale
Postby Crampy » Wed Aug 30, 2006 11:38 am
Not a problem at all man.
Crampy
Postby Bling » Wed Aug 30, 2006 5:19 pm
now ya say that :oops:
live and learn i guess, I made this mistake using a generic fork one..... boot split and mashed.... I should have thought ahead as to what would happen... live and learn (only a kp one tho, 10 bucks got me basically a whole steering rack for spares :P)
