any help?
(see pic below)
(and yes i have undone the nuts!)
its the ba$tard under the CV that is the problem!
KinLoud wrote:I think that where the long arm bolts to the hub there is small cotter pin (no pun intended) that holds it in place? Long time since I did this on my old ae101 gtz though. You will have to remove this pin to remove the arm.
yup, you got my number eh? 027 499 6263Mr Revhead wrote:DONT use a generic fork type splitter as it WILL root the joint.
got pxt? ill send you a pic
