for f/sake 4 age turbo issuses
Postby trdfxgt » Mon Sep 04, 2006 3:45 pm
my 4 agte is still blowing smoke !!!!! it is all to do with the oil feed to the turbo i have restricted it down to 40 thou and its stiil over feeding it !!! can any one give me some ideas cos i want to get it tuned but it will fill the work shop with smoke i have removed the feed line and tried it just by running it with a oil can feeding it and the smoke goes away so i am 100percent sure this is the problem
trdfxgt
Postby strx7 » Mon Sep 04, 2006 3:49 pm
sure it hasn't got a blown oil seal in the turbo?
Postby IH8TEC » Mon Sep 04, 2006 4:23 pm
how good is your oil return?
Postby trdfxgt » Mon Sep 04, 2006 4:30 pm
mint return good size in the right place on the sump also iv tried 3 different m10 tubos all do the same thing
trdfxgt
Postby IH8TEC » Mon Sep 04, 2006 4:34 pm
sorry, i'm referring to the angle of it. is there much drop from the oil return to where it goes into the sump?
Postby trdfxgt » Mon Sep 04, 2006 4:57 pm
its good about 45 degrees i guess oil drains away fine i must have over looked something but i cant for the life of me think what
trdfxgt
Postby Bazda » Mon Sep 04, 2006 5:42 pm
can u post pics up of the oil return pipe and inlet.
Postby edwagon » Mon Sep 04, 2006 7:11 pm
Its amazing how fussy turbos can be with oil drains - don't dry the turbo up too much (ie: restrict feed) unless you're 110% sure its not a drain problem.
edwagon
Postby YeMs » Mon Sep 04, 2006 7:49 pm
yeh i had a mate in whakatane who had a similar issue. all came down to the oil drain. the pipe work had to much drop before it went into the sump and was collecting.
Your local Hybrid Elite tech
YeMs
Postby Drifter4ag » Mon Sep 04, 2006 10:09 pm
is the turbo $&#$%?
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby no_8wire » Mon Sep 04, 2006 10:20 pm
trdfxgt wrote: iv tried 3 different m10 tubos all do the same thing
I would say its not the turbo...
no_8wire
Postby Drifter4ag » Tue Sep 05, 2006 8:51 am
m-tens are a ho hum turbo though.
Also check your motor for crank case pressure .. i.e. make sure you are running 2 breathers on the head .. i had a issue like this maybe 3 years back ... turned out to be a cracked piston...
1.cracked piston
2.Oil feed still too large
3.Drain too small , on rong angle
4.Engine cant breathe sufficiently
5.Turbos no good
seeing as its using m-ten series turbos just go find or borro a t25 running lo kms and see if thats any different. Remember that that model or turbo ceased production in maybe '84 so you are using an oldie and if not rebuilt i put my money on the oil seals.
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby trdfxgt » Tue Sep 05, 2006 9:14 am
is a t25 the same ?? it would be good to try a later model turbo cos that was one thing i thought of
trdfxgt
Postby DexGT » Tue Sep 05, 2006 9:55 am
I have exactly the same problem on my starlet with a T25 on , 1mm feed hole , 19mm outlet good drop to factory sump fitting . Unfortunatlly I can't tell you how to fix it as I haven't managed to fix mine yet either :(
I too am almost certain that its a draining problem , but I have checked the sump for presure buildup (none) .
My plans are to
(1): fit a presure regulator on the feed line and see if this helps,
(2): trial a pump on the turbo drain to see if this improves it
(3):try something else if these ideas don't fix it
I also have had 4 diferent turbos (2 freshlly rebuilt ) on the car and the problem stays the same annoying bloody smoking .
good luck sorting your problem
DexGT
Postby MrOizo » Tue Sep 05, 2006 12:21 pm
I had this prob too in my AW11. what i did to eliminate the turbo being at fault was have the feed restricted to about 2-3mm and then had the return drain into a bottle on the ground...
try that and see what happens :)
MrOizo
Toyspeed Legend
Postby drftnmaz » Tue Sep 05, 2006 9:28 pm
how low does the turbo sit?
drftnmaz
Postby 1598cc » Tue Sep 05, 2006 11:47 pm
oil return needs to be downhill.. its gravity feed..
1598cc
Postby matt dunn » Wed Sep 06, 2006 12:55 am
MrOizo wrote: and then had the return drain into a bottle on the ground...
Was about to suggest that.
Run a drian hose from the turbo straight out the bottom of the turbo thru a hose to some sort of catch bottle or oil drain tray.
Then start and run for a while and see what the result is.
If it's ok, then the oil drain is the problem.
If not, the has to be the turbo if removing oil pressure to the turbo stops the smoke.
Postby Akane » Wed Sep 06, 2006 7:10 am
What is the angle of the feed? as in, does the feed hole point straight up to the sky?
Postby trdfxgt » Wed Sep 06, 2006 10:23 am
the return is fine i am red faced in saying this but it appares it is that all 3 and now a fourth turbo are $&#$% they all every one have leaking exhaust oil seals i cannot beleive 4 of them are $&#$% ha ha ha ha ha this sucks sent away for rebuild will update what happens
trdfxgt
