Check light being odd
Postby Pelo » Mon Sep 04, 2006 7:26 pm
I put bluetop cams in my 4agze on the weekend, it is noticeably more responsive, can't feel any more power though. Worth the small effort, only took a couple of leisurely hours.
But since fitting the cams my engine check light is intermittently coming on, it will light up for about 5-10 seconds at random times, then disappear again. No idea what is causing it?!?
Pelo
Postby Lloyd » Mon Sep 04, 2006 7:50 pm
Check the fault codes and see if anything comes up
Postby Ae92typeX » Mon Sep 04, 2006 9:42 pm
wont cause the light, but did you re-shim it with the cam change?
Ae92typeX
Postby Pelo » Tue Sep 05, 2006 12:22 am
Not yet, haha. It is quite rattley at the moment!
Pelo
Users browsing this forum: Bing [Bot] and 4 guests
