Serious knocking when on hard lock...
Postby Quint » Sun Sep 10, 2006 1:12 am
Ever since i have put a temp. replacement set of alloys on the front of my car (cheers johnny :D) whenever you go to hard right lock there is a substantial 'knocking', not just a click, but the car physically moves up and down.
Anyone know what could be the problem, When i crashed, the rear end took the impact so i don't think its the rack at all, recently had a wheel alignment (a week) so it can't be the tyre hitting the gaurd, so confused >_<!
It can't be a CV because its a RWD.
Quint
Postby Jazza » Sun Sep 10, 2006 9:13 am
Are the wheels in perfect condition? Could be substantial damage to one of them?
1996 Curren - On Tardme
Jazza
Postby eritate » Sun Sep 10, 2006 10:49 am
ummm have you made sure the wheel nuts are tight as a mofo ? :roll:
I am a timewaster. Ignore anything I say
eritate
Postby Mr Revhead » Sun Sep 10, 2006 10:56 am
any one who does there wheel nuts up as "tight as a mofo" is a $&#$% idiot.
which corner of the car moves? and which corner is the noise coming from?
Postby eritate » Sun Sep 10, 2006 11:05 am
Mr Revhead wrote:any one who does there wheel nuts up as "tight as a mofo" is a $&#$% idiot.
haha. i didnt mean like rattle gun tight :P but at least tight enough so all your weight is pushing down on the nut :)
everyone does things different ways
Mike
eritate
Postby Mr Revhead » Sun Sep 10, 2006 11:09 am
use a torque wrench.
if i put all my weight on it its waaaaay too tight.
some where arounf 65lbs is where you want it.
also i small amount of anti sieze is a good idea. and make sure the seat is clean
Postby 2LTR Rona » Sun Sep 10, 2006 11:31 am
check your left rear, a mate had a customer who complained of a bumping type situation coming from the front when cornering a certain way, turned out the rear tyre had a serious amount of damage to it, transfering this to the front.
As yours has had a rear hit it, on the drivers side if i remember correctly, then it could have pushed things out of alignment & when cornering right your loading the left side, hence the knocking.
just a though
2002 Altezza, 1974 KE25
2LTR Rona
Postby Quint » Sun Sep 10, 2006 7:21 pm
Wheel nuts are fine, one of the tyres is _semi_ bald, but thats nothing to worry about.
The wheel that took the impact was taken off the car (it was $&#$%) and i put the front ones on the back and the replacements on the front (they are significantly smaller) Only thing i can think of is that the chassis got tweaked, and if it has..... $&#$%.
To better describe it the 'clicking' comes from the right (i believe) and the entire front of the car shudders and probably moves about 20mm up and down through each 'click' cycle. So messed up.
Quint
Postby Mr Revhead » Sun Sep 10, 2006 7:25 pm
get it on jack stands and have a look
for that to happen you will be able to see what it is easy.
cant internet mechanic crash damage
Postby Quint » Sun Sep 10, 2006 8:17 pm
Mr Revhead wrote:get it on jack stands and have a look
Had it up on stands when i was replaceing the rear crank seal, didn't notice anything funny/unusual... except maybe that the (not sure what its called) strengthening arm that goes accross the rear of the sump from suspension arms was loose (NOT SWAY BAR) (as in bolts), but that could have just ben rattling loose very slowly, as i don't know how a knock would do that.
But even in saying that the chassis has moved, the lower control arm would have gone before that, and its fine, about the most i did was ruined the bearing in the hub and goosed my alloy.
I'm completely perplexed :(
Quint
Postby drftnmaz » Mon Sep 11, 2006 1:03 pm
sounds likt something is binding somewhere or you useing a set of wheels with a higher offset and there contacting the sway bar or soemthing.. i'd check around the stub axel area for scratched/polished bits etc
drftnmaz
Postby Cakky » Mon Sep 11, 2006 5:31 pm
are you using shank and washer nuts? i put new wheels on my car with these nuts and got a similar sounding clicking sound, turned out the nut wasnt completely flush against the hub ( it looked flush but wasnt ) and putting a second washer on each nut got rid of this.
or there could be play between the wheel nut and nut hole...
1989 Corolla GT sedan blacktop 20v
Cakky
Postby RickGT » Tue Sep 12, 2006 10:25 pm
had this problem on my fx
turned out to be the the inner tread of the tire was rubing on the wheel arch sumwhere and each time the tread went past and rubbed it caused the car to bump up and down like you were saying, this only happend at very low speed, if i was doing a u turn it would make a clicking rubbing sound. look in the wheel arch and c if you can see any wear or anything where it could of been rubbing
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby Quint » Thu Sep 14, 2006 2:10 pm
Had a good investigation today. Nothing seems to be fouling on the gaurds, put it on hard lock both ways, still the same, nothings rubbing! I just don't understand...
Could it be the powerstearing belt slipping or anything like that? I was thinking it could be the oil, but theres plenty enouhg in there (and u'd notice it other times, not just a hard right lock)
Quint
Postby MetalupYoAss » Sat Sep 16, 2006 12:48 pm
i had a similar problem on ae85, check your wheel bearings for play, and check your ball joints
MetalupYoAss
