sergei wrote:Use power transistor with heat sink as voltage follower. if you connect the interior lights directly it will overload the dimmer circuit for light in the barrel.
If you don't want the dimmer function, but want just a delayed switch off, use relay to switch the interior lights off/on controlled by light dimmer from barrel.
