leasson on cam gear plz ?
Postby dougsop » Wed Sep 20, 2006 12:14 pm
can anyone tell me wat does cam gear do where is it and how to pick a set ?
after a set for my st205
97 Toyota GT4 ST205 1st run 16.2psi 181.2KW
more to come...
dougsop
Postby Jebus » Wed Sep 20, 2006 12:19 pm
In short, they fine tune your cams, can help lumpy idles and move the power around a tiny bit.
If you dont have aftermarket cams, not really any point.
Stickers are cheaper
Jebus
Postby Si » Fri Sep 22, 2006 8:20 pm
Some gains can be made just with standard cams, i had a dyno plot of a rb26, with a few degrees of cam change it made a extra 8kw or so...
cant find it now however :(
Current: , '96 SubaruImpreza
Si
Postby matt dunn » Fri Sep 22, 2006 8:42 pm
Si wrote:cant find it now however :(
Hmm, 8kw is quite small,
Maybe it's under your bed?
Postby I TRD I » Sat Sep 23, 2006 4:20 am
Cam timing adjustment will only giive power increases at a particular rpm
go to bill sherwood home page to learn more
NZ new AE82 GT sedan I TRD I was stolen in january still nothing recovered ! I TRD I is now a notchback ae85 with full ae86 running gear , high comp pistons , hks cams , etc
I TRD I
Re: leasson on cam gear plz ?
Postby Ae92typeX » Sat Sep 23, 2006 8:53 am
dougsop wrote:can anyone tell me wat does cam gear do where is it and how to pick a set ?
No offence intended at all, but what made you decide you were after a set if you didnt know what it did etc?
Ae92typeX
Postby dougsop » Sat Sep 23, 2006 1:02 pm
going to rebuild my gt4 soon, just trying to understand more abt the parts and wat it does.
more to come...
dougsop
Postby Si » Sat Sep 23, 2006 7:26 pm
an example of cam tuning using adjustable cam degree wheels on a R32 GTR with std size turboes at 15 PSI. Interestly this result was obtained solely by adj the degree wheels with no ECU tuning at all.
Si
