Caldina GT-T mods
Caldina GT-T mods
Postby CaldinaGt_t » Mon Sep 25, 2006 4:39 pm
any tips and info on making power? simple mods
3SGTE POWER RULES!
2000 Caldina GT-T
TD05-BIG16g,o2 housing wid external dump pipe, front mount intercooler, speed limiter removed, 1jz-gtte pistons, and lots of boost
CaldinaGt_t
Postby strx7 » Mon Sep 25, 2006 8:52 pm
if you want RELIABLE safe HP increases you need to be able to alter the timing and/or fuel delivery.
Internally the engine is reasonably strong and will handle a larger turbo and therefore more HP, but you NEED tunability.
Postby $CENSLS1$ » Mon Sep 25, 2006 9:49 pm
As per usual Intake and Exhust would be the best place to start.This should free things up.Then get some kind of boost control, electronic would be the best.But just something that you can use to make sure it doesn't overboost.
If you want to go much furthur you'll need to let us know your budget ;)
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Postby strx7 » Mon Sep 25, 2006 10:04 pm
AFAIK factory boost is like 14 psi, 17-18psi on 96 pump gas = melted pistons
Postby Silent Knight » Tue Sep 26, 2006 9:24 am
strx7 wrote:AFAIK factory boost is like 14 psi, 17-18psi on 96 pump gas = melted pistons
Yea they run just under 1bar factory boost.
Silent Knight
Postby Santa'sBoostinSleigh » Tue Sep 26, 2006 10:07 am
and its all been covered many times
search.php
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby CaldinaGt_t » Tue Sep 26, 2006 12:48 pm
i have the following mods already:
1. front mount intercooler
2. Boost controller
3. 3 inch downpipe, 2 1/2 inch to where the bend near the back(right at the back wheel) is 3 inch into the drum.
4. fuel pressure up mod
5. Tubular Exhaust manifold with stock turbo
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby CaldinaGt_t » Tue Sep 26, 2006 12:49 pm
and
6. a Cold air system being setup
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby IH8TEC » Tue Sep 26, 2006 12:58 pm
pays to put stuff like that in the first post so people know from there :wink:
