I've been having a random problem with my GT-T. I've very randomly been getting the check engine light come on with the VSC light and the Over Drive light flashes. The other interesting thing that happens is the tacho and speedo stop working.
After the first time it did it I took it to Shore Performance to get it diagnosed and it popped up as a speed sensor malfunction. Since they didn't have any experience with Caldinas I decided to not get them to fix it. I've had the airbox out and found there is two speed sensors. One on the front of the box and one on the top. A friend at Toyota confirmed that they are identicle and have the same part number. I bought one new one and swapped that in and it defnitely made a difference, drove heaps smoother and the error went away for quite a while but now I'm getting it pop up every now and then - say once ever 500km or so.
Does anyone have any experience with an error like this? I'm set to buy another sensor so both are new but at $160 each (retail is over $200) I'm not sold this will fix it. Next thing I'm going to look at is the wiring and see if there is a short or bad earth. Any thoughts?
