Caldina Speed Sensor Error
Postby Stu- » Sun Oct 01, 2006 4:52 pm
I've been having a random problem with my GT-T. I've very randomly been getting the check engine light come on with the VSC light and the Over Drive light flashes. The other interesting thing that happens is the tacho and speedo stop working.
After the first time it did it I took it to Shore Performance to get it diagnosed and it popped up as a speed sensor malfunction. Since they didn't have any experience with Caldinas I decided to not get them to fix it. I've had the airbox out and found there is two speed sensors. One on the front of the box and one on the top. A friend at Toyota confirmed that they are identicle and have the same part number. I bought one new one and swapped that in and it defnitely made a difference, drove heaps smoother and the error went away for quite a while but now I'm getting it pop up every now and then - say once ever 500km or so.
Does anyone have any experience with an error like this? I'm set to buy another sensor so both are new but at $160 each (retail is over $200) I'm not sold this will fix it. Next thing I'm going to look at is the wiring and see if there is a short or bad earth. Any thoughts?
Project Thread
Stu-
Postby CaldinaGt_t » Mon Oct 02, 2006 5:39 am
is it an automatic? if so does it have gear changing problems like not going in to 4th gear?
if so check ur knock sensor.
3SGTE POWER RULES!
2000 Caldina GT-T
TD05-BIG16g,o2 housing wid external dump pipe, front mount intercooler, speed limiter removed, 1jz-gtte pistons, and lots of boost
CaldinaGt_t
Postby Santa'sBoostinSleigh » Mon Oct 02, 2006 3:13 pm
CaldinaGt_t wrote:is it an automatic? if so does it have gear changing problems like not going in to 4th gear?
well i havent ever seen a manual with VSC or overdrive
like you said - check earths and connections
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Stu- » Mon Oct 02, 2006 6:48 pm
Yeah its Tiptronic. Has no problem changing gears even with the errors. Drives perfectly.
Project Thread
Stu-
Postby cynakyl » Wed Oct 04, 2006 6:45 pm
the speedo problem has happened to me a couple of times and to quite a few other gt-t owners IIRC. With mine i just turn the car off, wait a few sec's, turn it on again and it usually fixes itself.
Driving a honda is like being in the special olympics. Even if you win, you're still retarded...
cynakyl
Postby FXGTV » Wed Oct 04, 2006 9:08 pm
I have a similar problem in my auto aw11. After the speedo cable snapped the overdrive light flashes and over 80kph the engine check light comes on. Hmmm
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby Stu- » Thu Oct 05, 2006 7:43 pm
cynakyl wrote:the speedo problem has happened to me a couple of times and to quite a few other gt-t owners IIRC. With mine i just turn the car off, wait a few sec's, turn it on again and it usually fixes itself.
Yeah thats what happens, only randomly thou, once in a blue moon. Would like to figure out what it is.
Project Thread
Stu-
Re: Caldina Speed Sensor Error
Postby XERO » Thu Oct 05, 2006 9:06 pm
Stu- wrote:I've been having a random problem with my GT-T. I've very randomly been getting the check engine light come on with the VSC light and the Over Drive light flashes. The other interesting thing that happens is the tacho and speedo stop working.
My friend I had the same problem... The problem is not in the speed sensor but in the gauge cluster itself... My problem was worse the first time it happened where the car went into spastic mode and everything went to arse... I took the car to an auto elec, he called back 5 mins later saying it was all fixed and all he did was tugged on the dash board... The problem continued to a point where the speedo and tach stopped working every now and again, and all it took to fix was a hard slap anywhere on the dash... eventually it all stopped working all together so I took it back to the auto elec and he came back to me saying it was a bad solder in the dash unit... They sent it off to a cluster specialist who fixed the problem and now all is fine and dandy!!! :wink:
hope this helps... Mark
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Stu- » Thu Oct 05, 2006 10:32 pm
Ah, thats what I was after. I had a sneaky suspision it may have been the cluster. Who fixed yours?
Project Thread
Stu-
Postby XERO » Fri Oct 06, 2006 8:45 am
Stu- wrote:Ah, thats what I was after. I had a sneaky suspision it may have been the cluster. Who fixed yours?
I took mine to barry auto electrical in kumeu and they sent it to a dash specialist
XERO
Postby Stu- » Fri Oct 06, 2006 6:52 pm
Cool, cheers, might give them a call.
Project Thread
Stu-
