AE86 with 3SGTE and 4WD
Postby CaldinaGt_t » Wed Oct 04, 2006 5:14 pm
can it be done, what are the parts needed to do this?
3SGTE POWER RULES!
2000 Caldina GT-T
TD05-BIG16g,o2 housing wid external dump pipe, front mount intercooler, speed limiter removed, 1jz-gtte pistons, and lots of boost
CaldinaGt_t
Postby NZ_AE86 » Wed Oct 04, 2006 5:27 pm
it can be done.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby AE85coupe » Wed Oct 04, 2006 6:13 pm
it can be done
parts:
get a gt4 celica
cut the body off
weld on an AE86 body
or
make a space frame chasis with 4wd and 3sgte running gear, then put an AE86 shell on that
i hope you have disgusting amounts of money to do it though
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby strap-on » Wed Oct 04, 2006 6:29 pm
no offence but if you have to ask you proabably shouldnt attempt it
strap-on
Postby AE85coupe » Wed Oct 04, 2006 6:31 pm
strap-on wrote:no offence but if you have to ask you proabably shouldnt attempt it
so very true
if you have to ask about it, the chances of you actually doing it are so so so slim
Details of car here
AE85coupe
Postby strap-on » Wed Oct 04, 2006 8:08 pm
like most of my ideas :lol:
strap-on
Postby AE85coupe » Wed Oct 04, 2006 8:09 pm
strap-on wrote:like most of my ideas :lol:
yeah but where would humanity be without people who come up with hair brained schemes???
Details of car here
AE85coupe
Postby Mr Revhead » Wed Oct 04, 2006 8:18 pm
thats my line!!!
ill help. come round, bring an ae86, a gt4 and a gas axe :D
Postby AE85coupe » Wed Oct 04, 2006 8:22 pm
hahaha now thats gold (don't forget the welder)
i bet you can pull it off too, sure it may look a little rough, and sure it may not work that well, but hell it will be a 4wd 3sgte ae86 right?? right?....
Details of car here
AE85coupe
Postby Scotty » Thu Oct 05, 2006 12:26 am
Who need a welder im sure zip ties will hold it :lol:
Scotty
Postby Mr Revhead » Thu Oct 05, 2006 8:43 am
zip ties can hold rally winners together so a revhead special will go fine with them 8)
Postby CaldinaGt_t » Thu Oct 05, 2006 3:03 pm
why so much, couldnt you just get a St185 Gearbox,ST185 Back end,St185 front end and custom mounts.
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby CaldinaGt_t » Thu Oct 05, 2006 3:06 pm
look how simple them put a 4WD drivetrain with a 3SGTE in the Toyota Runx and The 2002 shape celica.
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby Punter » Thu Oct 05, 2006 3:37 pm
Well no it's probably no harder than doing it to any other car.
If you think its simple then do it.
Although would an ae86/5 be wide enough in the engine bay, they wern't designed for a transverse motor
Punter
Postby NZ_AE86 » Thu Oct 05, 2006 4:39 pm
If I was to do it I would use a North/South layout and use a Subaru Gearbox with a good gearkit.
You would need quite a bit of Fabrication around the front end but it could be done.
Current rides;
1986 Levin GT
NZ_AE86
Postby Adamal » Thu Oct 05, 2006 4:49 pm
The easiest way to get the bits you need off a GT4:
Postby deaf_rattle » Thu Oct 05, 2006 6:17 pm
wow, a pic of brad without a cast or bandage on.
And the 4wd 3sgte 2000 shape celica, sure its been done....
rod millens work shop did the work. That car has had a shit load of money spent on it. I heard close to a mill, but that seems awfully high.
Postby Adamal » Thu Oct 05, 2006 6:24 pm
deaf_rattle wrote:wow, a pic of brad without a cast or bandage on.
Yes, well then when we went to get the shell back down.... NAAAHHH JUST KIDDING AU!!!!
Postby $CENSLS1$ » Fri Oct 06, 2006 10:20 am
Just out of curiousity, why the *uck would you want a 4WD Ae86? :roll:
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Postby RS13 » Fri Oct 06, 2006 12:46 pm
Hybrid rally car perhaps? But then, you still wouldn't wanna crash it, with the shortage of AE85/86 shells.. if I wanted to spend tens of thousands building something Toyota, with 4WD and 3SGTE, I'd get one of these:
Its' such a shame the base model never came to NZ, one of the nicest looking Corollas IMO!
RS13
