driveshaft loop
driveshaft loop
Postby repowered » Thu Oct 05, 2006 12:26 pm
hey
what do i need to do for this driveshaft loop and where does it need to be placed? i think its 150mm back from gearbox?
any pics of what people have done? is somthing like a U bolt ok?
is for a 4age, ke30.
Rollin!
repowered
Postby 2LTR Rona » Thu Oct 05, 2006 12:40 pm
dont know about the exact specs.......but the KE I have has one, put in by previous owner.
just a piece of flat bar about 20mm in width from memory that has been bent in to a loop then bolted through the floor & both ends of the flat bar.
Dont have a pic of it sorry.....but should give you an idea
2002 Altezza, 1974 KE25
2LTR Rona
Postby repowered » Thu Oct 05, 2006 12:51 pm
2LTR Rona wrote:dont know about the exact specs.......but the KE I have has one, put in by previous owner.
yep i get the picture. can you remeber if it was dead in the middle of the driveshaft or towards one end?
thanks man
Rollin!
repowered
Postby 2LTR Rona » Thu Oct 05, 2006 12:54 pm
wasnt that far behind the universal joint fom memory, rough guess off the top of my head would put it somewhere below the handbrake, give or take a bit.
2LTR Rona
Postby repowered » Thu Oct 05, 2006 8:43 pm
2LTR Rona wrote:wasnt that far behind the universal joint fom memory, rough guess off the top of my head would put it somewhere below the handbrake, give or take a bit.
cool thanks
Rollin!
repowered
Postby Mr Revhead » Thu Oct 05, 2006 8:52 pm
best to ask the authority that requires you to have one
Postby repowered » Fri Oct 06, 2006 8:41 am
Mr Revhead wrote:best to ask the authority that requires you to have one
yeap i have, when i asked about it the certifer wasnt there but one of the other guys talked to be about it , need to talk again to certifier in more detail.
Rollin!
repowered
Postby Jebus » Fri Oct 06, 2006 9:31 am
Use 50 X 6mm Steel, and can be anywhere up to 150mm from behind the rear of the universal.
I bnet mine up in two pieces and then welded it super strong, it bolts through the floor just in front of my front seats.
Those are the rules as according to Mark Stokes.
Jebus
Postby repowered » Fri Oct 06, 2006 11:15 am
Jebus wrote:Use 50 X 6mm Steel, and can be anywhere up to 150mm from behind the rear of the universal.
cheers for that man i was gunna PM ya. yea 150mm is whats on http://www.lvvta.org.nz/.
ok i'll have to get somthing made up this weekend.
churz
Rollin!
repowered
Postby l1ttle_d3vil » Fri Oct 06, 2006 12:05 pm
just had my engine out yesterday and car over the pit so could've got some pics of mine for you. it has to be bolted to the floor with two bolts each side (so 4 all up) too.
mine was done in two separate pieces that sit together when its all bolted up, easier to take apart that way.
i'll see if i can get some pics of mine for you still though...
Postby repowered » Fri Oct 06, 2006 1:03 pm
l1ttle_d3vil wrote:just had my engine out yesterday and car over the pit so could've got some pics of mine for you. it has to be bolted to the floor with two bolts each side (so 4 all up) too.
oh yea try get sum pics man
i was just going to get a m8 at work to fart up a U with 2 Flat ends. Does it have to be like a ring around the whole shaft or is a U ok?
best to see a pic :)
Rollin!
repowered
Postby wde_bdy » Fri Oct 06, 2006 1:05 pm
And if you have a 2 piece driveshaft you need 2 loops. :roll:
wde_bdy
Postby Jebus » Fri Oct 06, 2006 1:20 pm
Needs to go round the whole ting bro, mine isnt in ATM, so ill try get a pic up for you today, but am running Linux live off a disc so will see how I get on...
Jebus
Postby repowered » Fri Oct 06, 2006 1:23 pm
Tru Bae! oh yea just reading that http://www.lvvta.org.nz/ site and it sez it needs to be 360 Deg so it cant contact road surface or floor.
yea ill get the guys here to make somthing up for me :) pics wld be mint
Rollin!
repowered
Postby Jebus » Mon Oct 09, 2006 9:08 pm
Sorry about the excessive $&#$% around bro!
Thats just 50 X 6mm Mild steel, just quickly bent it up in the vice then zapped it together. Fits really snug, about as big as you could fit in the tunnel and a Hilux diameter driveshaft just fits within it.
Jebus
Postby repowered » Tue Oct 10, 2006 2:57 pm
chur chur man
getting made today!
Rollin!
repowered
