4agte is driving me NUTS!!!
Postby SpeedRacer » Fri Oct 06, 2006 9:05 pm
ok, the fact that this wont start is really starting to fcuk me off big time so lets clarify some things
I have spark and fuel.
-the dimple on the exhaust and intake cams should be facing up at tdc?
anything else ill add later
-Speed
Sinister Sleeper 35
SpeedRacer
Postby no_8wire » Fri Oct 06, 2006 9:39 pm
What engine you got? 16v or 20v?
on 16 when the dimple on the intake cam is vertical the exhaust is supposed to be at 5 o'clock..IIRC
no_8wire
Postby SpeedRacer » Fri Oct 06, 2006 9:42 pm
yep 16v
btw wot the hell is iirc?
Sinister Sleeper 35
SpeedRacer
Postby l1ttle_d3vil » Fri Oct 06, 2006 9:49 pm
iirc = if i remember correctly.
with the bottom crankshaft pulley at TDC, theres a couple of dots on the top two pulleys which line up with a couple of notches on the engine mould behind them.
i think thats what you're asking anyway... :roll:
Postby no_8wire » Fri Oct 06, 2006 9:50 pm
If I remember correctly...I will go check my manual...
yeap 12 & 5
no_8wire
Postby SpeedRacer » Fri Oct 06, 2006 9:52 pm
nup thats on the cam wheels, i mean on the shafts themselves
Sinister Sleeper 35
SpeedRacer
Postby l1ttle_d3vil » Fri Oct 06, 2006 10:08 pm
haha, i was wondering if you were doing a turbo conversion why you wouldn't even know how to set the cam timing yourself :lol:
Postby SpeedRacer » Fri Oct 06, 2006 10:14 pm
yea nah took the cams out 4 months ago and for the life of me cant remember how they go back in, man im useless :(
Sinister Sleeper 35
SpeedRacer
Postby slighty_sykotic » Fri Oct 06, 2006 10:16 pm
Hey,
The cams are right now. Unless you have changed them again.
What happened to your car...
It was going in my garage?
--Sykotic
slighty_sykotic
Postby SpeedRacer » Fri Oct 06, 2006 10:19 pm
i thought they were right, havent changed them, but i was looking at this pics and wasnt sure if it was right or not.
http://s16.photobucket.com/albums/b20/M ... =imgAnch15
its at my house, exhaust done etc....
pretty sure the guy doin the exhaust took the dizzy out and fcuked things up
EDIT:: ill have another look again tomorrow when its lighter and i have some better tools :?
Sinister Sleeper 35
SpeedRacer
Postby slighty_sykotic » Fri Oct 06, 2006 10:24 pm
Yeah, he would have.
In which case it will be the same problem remember.
The dizzy is just out, put motor to TDC, take out dizzy, align the rotor to just before spark plug contact one, then put it in.
--Sykotic
slighty_sykotic
Postby MrOizo » Fri Oct 06, 2006 10:43 pm
if you havent got the cams right yet:
take the covrs off and have a look at the #1 section. the lobes for the #1 for intake and exaust should be pointing outwards. that will give you an idea on where the pins should be pointing :)
oh and your timing might be 180 degrees out..
make sure you are on the compression stroke when lining up the dizzy... check that the lobes are pointing out!
MrOizo
Toyspeed Legend
Postby Caveman » Sat Oct 07, 2006 1:01 am
matt dunn posted a good reply on how to set the timing.
Basically you clock the crank so its at zero timing and you can see the dimple though the oil filler.
next remove the dizzy and turn it so the dimple is facing upwards. This is sometimes akward because the helical gear is hard to line up properly with the gear on the cam shaft.
If its still not starting bridge terminals E1 and TE1 on the diagnositcs plugs and tell us what it reports.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby SpeedRacer » Sat Oct 07, 2006 9:44 pm
yea thats where i got the pics from.
oh and bridging any thing is no good cos im running a link ;)
Sinister Sleeper 35
SpeedRacer
Postby Skin » Sun Oct 08, 2006 2:53 pm
[quote="MrOizo"]
quote] Thats just what i was thinking. Ha i have done that before.... :oops: :lol:
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby SpeedRacer » Sun Oct 08, 2006 9:25 pm
got it sorted, now for it to hold idle..... :?
Sinister Sleeper 35
SpeedRacer
