gtz flywheels
gtz flywheels
Postby bluemaumau » Tue Oct 10, 2006 9:46 pm
can anyone confirm wether ae92 and ae101 flywheels are the same size?
Postby Mr Revhead » Tue Oct 10, 2006 10:09 pm
theres 2 types
change during ae92
Postby bluemaumau » Wed Oct 11, 2006 12:39 am
shit, so if i was to run a ae101 p plate and clutch id need a ae101 flywheel?
Postby Mr Revhead » Wed Oct 11, 2006 9:31 am
yep. or a late ae92 one.
not easy to find i have found
Postby bluemaumau » Wed Oct 11, 2006 3:36 pm
$&#$% just out interest,
1 what are the exact sizes
2 do you need a ae101 gtz starter motor if you upgrade to the ae101 flywheel?
Postby bluemaumau » Wed Oct 11, 2006 3:45 pm
3 can i run a ae92 p plate, clutch and flywheel on a e58 lsd box?
Postby bluemaumau » Wed Oct 11, 2006 4:02 pm
i just searched thru the for sale section and found info in there,
change in flywheels was in 1990. ae92 afm and ae92map/ae101 clutches are not interchangable.
can anyone tell me wether i can run a ae92 afm starter motor on a late model flywheel, or post a pic up of a ae101 gtz starter
thanks
Postby crnkin » Wed Oct 11, 2006 6:36 pm
bluemaumau wrote:i just searched thru the for sale section and found info in there,
thanks
starters are mint :)
deaf_homo "currrently yes"
crnkin
Postby bluemaumau » Wed Oct 11, 2006 7:19 pm
thanks
so it wont or will fit ? :lol:
Postby crnkin » Wed Oct 11, 2006 10:47 pm
All a series ring gears are the same size and tooth. And i have a sneaky suspision all toyota ones are the same size, though i may be wrong, someone once told me that anyways.
So yes, you will be fine. 4age, 2e, 1g, 4agze, smallport, bigport, will all do the trick. (1g needs the flange ground a tad, but mega high torque start y0)
crnkin
Postby bluemaumau » Wed Oct 11, 2006 10:49 pm
sweet, i know my 4afe one didnt fit the gze/e series combo, but id say that its all in the mounting points rather than teeth etc, but cheers for your input :)
Postby crnkin » Wed Oct 11, 2006 10:52 pm
bluemaumau wrote:sweet, i know my 4afe one didnt fit the gze/e series combo, but id say that its all in the mounting points rather than teeth etc, but cheers for your input :)
Yeah, thats the bolt spacing. You just re drill the flange and your away
crnkin
Postby bluemaumau » Wed Oct 11, 2006 10:55 pm
$&#$% didnt think of that!
owell i just redid bushes and its mint now!
sweet
Postby bluemaumau » Wed Oct 11, 2006 11:41 pm
to sum this up for the next person:
gtzs flywheels changed when the ae92 facelift was released.
the two eras clutches are not interchangable.
