Toyota Sealant---how can you remove it?
Postby no_8wire » Wed Oct 11, 2006 8:48 pm
I want to get all the old sealant off the oil pan, so I can put new sealant opn. What can I use to get the sealant off? Thinners just glides over it...and hto water/ degreaser doesnt soften it...
Any help on how to get it all off?
no_8wire
Postby trueno_20v » Wed Oct 11, 2006 8:53 pm
wire brush works good :lol:
ADMIN EDIT: signature too large
trueno_20v
Postby Lloyd » Wed Oct 11, 2006 9:10 pm
Yep, wire brush or a blade... although the blade doesn't get into the grooves
Postby no_8wire » Wed Oct 11, 2006 10:13 pm
My sump is a two piece...half is steel the other is aliminum...so I dont want to use a wire brusk on the ali as it will leave deep scratches etc...any other advice?
no_8wire
Postby Mr.Phreak » Wed Oct 11, 2006 11:19 pm
Blowtorch :twisted:
Mr.Phreak
Postby no_8wire » Thu Oct 12, 2006 6:06 pm
Not sure how well that would work on a high temp sealant...but at this point, anything that wont damage the ali sump is been considered
no_8wire
Postby z0ton » Thu Oct 12, 2006 6:09 pm
no_8wire wrote:Not sure how well that would work on a high temp sealant...but at this point, anything that wont damage the ali sump is been considered
A blow torch would go 5 times as hot as high temp sealent could handle...
z0ton
Postby no_8wire » Thu Oct 12, 2006 6:31 pm
and still not melt the ali..ok I will give that a try...
no_8wire
Postby ezy10s » Thu Oct 12, 2006 7:30 pm
razor blade most of it- then use the wire brush dude- on both the alloy and tin parts works fine.
Member #244
ezy10s
Postby IH8TEC » Thu Oct 12, 2006 8:06 pm
wire wheel on a bench grinder, worked a treat on mine.
Postby Quint » Thu Oct 12, 2006 8:39 pm
no_8wire wrote:and still not melt the ali..ok I will give that a try...
Ah, i'd go easy on that blowtorch idea, if it is aluminium as you say, it has a MP of around 800-900 C which wont be reached, but the temp required for the metal to start creeping will be. If you do it quickly, wont be a problem. But any longer and the metal will slightly deform due to its own weight.
Best way to go would be in the opposite direction, and freeze it.
But i'd just wire brush it :)
Quint
Postby no_8wire » Thu Oct 12, 2006 10:07 pm
heres a pic of the sump...
will try the wire brush[/url]
no_8wire
Re: .
Postby ezy10s » Thu Oct 12, 2006 10:13 pm
ezy10s wrote:razor blade most of it- then use the wire brush dude- on both the alloy and tin parts works fine.
Dude- howd ya think i sorted out the ones ive done!? A wire brush isnt gona $&#$% anything up
Member #244
ezy10s
Postby edwagon » Thu Oct 12, 2006 10:33 pm
Stop mucking aroud and just attack it with the wire brush! :D
Not sure if toyota grey does, but most silicone sealers don't like parts washer fluid, so you could try soaking it for a while and the silicone will most likely curl up and almost fall off.
edwagon
