oil leak!
oil leak!
Postby repowered » Thu Oct 12, 2006 9:15 am
hey
got drips of oil coming out between the engine and belhousing. not sure if its coming from the sump or the crank seal or the gearbox. i replaced the Rear Crank seal before the motor went in and has a new Spigot bearing. could see any evidence of major oil leaks around the sump beefore i put the motor in. i think ill whip the gear box off in the weekend and confirm where its coming from.
anywhere else around there where oil can come from - havnt had any clutch slip or anything like that.
engine is RWD 4age in Ke30, t50 gearbox.
Rollin!
repowered
Postby Jebus » Thu Oct 12, 2006 9:16 am
Well is it engine oil or gearbox oil? Smell it.
Can only really come from 2 places :P
Jebus
Postby Quint » Thu Oct 12, 2006 9:34 am
I got the same problem, most likely the input seal in your box.
But like jebus said, gearbox oil smells sulphury.
Quint
Postby Adydas » Thu Oct 12, 2006 9:45 am
LIKE FISH!!!
Adydas
Postby repowered » Thu Oct 12, 2006 11:05 am
Jebus wrote:Well is it engine oil or gearbox oil? Smell it.
yea ok ill smell it - i know what it smells like i got enough on me trying to fill the gearbox the other day!
Rollin!
repowered
