AE92 leak?
AE92 leak?
Postby deaf_rattle » Fri Oct 27, 2006 9:28 pm
I have taken the carpet out of my ae92 fxgt to try and find a leak.
On wet days i get alot of water building up on the drivers side, mainly in the foot well just infront of the seat.
it feels dry up by the firewall.
Is there a common leak in these cars? or will i need to keep searching?
Postby sergei » Fri Oct 27, 2006 9:34 pm
top/side of the windscreen or door seal.
Postby KinLoud » Fri Oct 27, 2006 10:31 pm
yeah - I know exactly where it will be leaking.
Water that goes down the vent between the bonnet and the windscreen... drains off to one side or another and flows out under the rear of the front guards and down the very front bit of the side panel that connects to the firewall. There is a seam as the water starts to flow downwards - this seam rusts out... take out the interior lining in the kickpanel area and look up with a torch and/or take the guard off and look through the holes in the covering panel. you can see the seam and the rust but you would have to cut a hole in the covering panel to get at the seam.
Awkward!
I hope I am wrong.
Ken
Ham
021 408 863
Postby deaf_rattle » Fri Oct 27, 2006 10:50 pm
thanks guys
sounds like a pain, but so is the smell when the carpet gets damp.
later on the car will get stripped abit for abit of track/motokahna use, but for now i want to put my carpet back in.
so might take the guard off and have a nosey.
